hydroboost questions - Ford Truck Enthusiasts Forums
Old 05-02-2014, 02:56 AM
highoctane74's Avatar
highoctane74 highoctane74 is offline
highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.
I was out looking for a hydro boost system for my truck today, as my master cylinder is leaking like crazy.
1) what year will bolt up to my truck? They have a 77 continental, early 90's astrology van with the 90 degree master cylinder, and a whole bunch of newer astrology vans with the master cylinders that are on an angle( I don't think they will work)?
2) what parts do I need to take? Master cylinder, power steering pump, both pump lines...anything else?
Thanks.
It's going on a 79 Supercab 4x4.
Old 05-02-2014, 08:42 AM
Jklnhyd's Avatar
Jklnhyd Jklnhyd is offline
Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.Jklnhyd has a very good reputation on FTE.
You can get a new rebuilt master cylinder from most parts houses for under $50. Why would you mess around with a junkyard part?
Old 05-02-2014, 09:04 AM
psychlopath's Avatar
psychlopath psychlopath is offline
psychlopath is gaining momentum as a positive member of FTE.
I'm not sure that any of those will just be a direct bolt up, but some of the more popular swaps from the parts you mentioned are from Astovans. It wouldnt hurt to get the steering pump from one as well. I'm not sure about all years, but all of the Astros that I have seen in junk yards have a remote reservoir Saginaw pump and a Saginaw pump swap with these hydroboost units is a very good idea!
All the write-ups I've seen (Including my own swap) required building a bracket to bolt the booster onto the firewall. After that, it was all plug 'n play to some degree.
Parts needed for JUST the booster swap would be the booster and master cylinder. The hoses may or may not fit as a direct swap. There are some variables involved that can be switched around to help you one way or another.
For example, there were at least two different pressure ports used on the Saginaw steering pumps that are interchangeable; there is an SAE inverted flare outlet and a metric O-ring outlet. It may make a difference if you decide to try to use factory hoses from some vehicle. When you are pulling parts, you can grab both outlets so you can swap them as needed. I think they use a 1" wrench or socket for removal.
Make sure you pay attention to which one you are using and dont just go by if they hose threads in or not, as a hose with the SAE flare will thread into both fittings.
Also, if you decide to do the pump swap and NOT get a remote reservoir unit from the Astrovan, try to get one with dual returns on the reservoir as that makes the swap look better and avoids having a T fitting in the line.
If you already have the Saginaw pump with a single return and want to swap it out, you can swap just the reservoirs if you need. There are several mounting configurations for them, but of the 30 or so I've tinkered with, they can all share reservoirs.
I built my own hoses because I was planning an engine swap. If you decide to go that route, I have some part numbers in a thread here: Some hydroboost progress + pic linx - FSB Forums
There are a few cautions in there about building your own hoses, regarding pressure ratings and fluid-hose compatibility. PTFE hoses are pretty damn good and you can get them from lots of places, like Jegs, Summit Racing or Aircraft Spruce, BUT they require PTFE hose ends and NOT regular ol' hose ends. Any time you build hoses, it is a good idea to have them pressure tested to above the working pressure they will be dealing with to ensure that your work will not strand you on the road. I can't remember, as it's been a few years since I've looked it up, but I think the Saginaw pumps put out between 1,100 and 1,300 PSI, depending on what vehicle they came in.
When I installed mine, I had to hire out the mounting bracket because for some reason welding inside of an apartment is frowned upon...but either way, I still have the contact info of the guy who can build a bracket. He gave me the OK to send people to him, but I'm not sure how Kosher it is to post it in a forum; if you need to have the bracket built, send me a PM and I'll send it to you.
If you really wanted to be lazy, he'll even ship you a SuperDuty master cylinder and booster, which is what all of the part numbers in the above link are for.
Good luck and post pictures.
Old 05-02-2014, 09:11 AM
4x4slik's Avatar
4x4slik 4x4slik is offline
4x4slik is gaining momentum as a positive member of FTE.
He is wanting to use a hydroboost system. It eliminates the vacuum booster and uses hydraulic boost from power steering pump to assist in braking.
Old 05-02-2014, 09:26 AM
Jklnhyd's Avatar
Quote:
Ahhh, ty. I will shush, lol
Old 05-02-2014, 10:17 AM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Check out this thread:
http://www.ford-trucks.com/forums/87...sion-done.html
It'll give you an idea of what you're getting into.
Master Cylinder Differences? F150? F250? Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 9 08-04-2016 04:29 PM
Dual master cylinder swap on a '66 bronco f250custom78 1966 - 1977 Early Broncos 1 01-18-2016 05:50 PM
Changing the booster and master cylinder on my coe pweng1 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-19-2014 10:51 AM
ZF5 Swap Master cylinder question: MPoulson Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 09-18-2013 09:35 AM
Master cylinder trouble shooting crazy96863 1973 - 1979 F-100 & Larger F-Series Trucks 18 05-08-2012 12:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
