Need advice on check engine light - Ford Truck Enthusiasts Forums
Old 05-01-2014, 09:00 PM
stnlycup's Avatar
stnlycup stnlycup is offline
stnlycup is starting off with a positive reputation.
'04 FX4 5.4
Backfired when I was starting it yesterday and shortly after the engine light came on..Not sure of the number of the codes, but 2 are "lean bank 1&2 MAF sensor" and the other 2 are for "lean bank 1&2 O2 sensor"
Im thinking the backfire clogged the MAF sensor. I tried to clean it with brake clean but it didnt seem to help.
Wondering if I should spend the $125 on a new MAF sensor in hopes thats the problem..or is there a better way to narrow it down?
Thanks in advance for any input
Old 05-02-2014, 08:51 PM
VTX1800N1 VTX1800N1 is offline
VTX1800N1 is starting off with a positive reputation.
Quote:
Originally Posted by stnlycup View Post
'04 FX4 5.4
You should now that you used brake clean on it. Use only MAF sensor cleaner on the MAF sensor.
Old 05-02-2014, 09:02 PM
stnlycup's Avatar
hmmm...didnt know there was such a thing....guess im making a trip to the parts store in the morning
Old 05-02-2014, 09:06 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Quote:
I will have to disagree with you on that . I have used brake cleaner for Many years on Maf sensors . I also use it on other electronic parts with good results . I just removed and cleaned out the under dash fuse / relay block on my 04 Mounty after a soda found it's way into it , Ask My Wife how that happened !
Old 05-02-2014, 09:16 PM
You take your chances, but brake cleaner can damage some of the insulating materials used in electronics. They make MAF cleaner specifically for that component.
Old 05-02-2014, 09:31 PM
JWC 3's Avatar
Never had an issue . All we use at the shop I work at now ( for 14 years ) used it at other shops for cleaning in the past . My brother in law in Chicago uses it also , he works for an electronics company . He told me about using brake clean .
96 F250 7.5L 460 PO171 ,174 CODES Mr f250 1987 - 1996 F150 & Larger F-Series Trucks 1 02-21-2016 11:25 PM
4.2 V6 Engine light after pulling spark plugs, got the codes from autozone jbourne84 3.8 & 4.2L V6 1 02-16-2016 10:10 AM
"service engine soon" light on after pulling spark plugs jbourne84 1968-2013 Full Size Vans 3 02-02-2016 07:06 AM
2002 B3000 P0172 issue resolved sawduck Ranger & B-Series 1 10-02-2015 01:12 PM
OBD2 Codes P0171 and P0174 Lean Bank 1 & 2 Unklebob Modular V10 (6.8l) 6 02-10-2015 06:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
