ZF 5 speed question
ZF 5 speed question
My truck has an early 4.14 first gear ZF 5 speed with God only knows how many miles on it. It was put in used when I got the truck.
The transmission is very loud at lower rpms and I'm sure it being so loose is what makes it so loud.
My question is, can I put a heavier viscosity oil in it to maybe quiet it down some and if I can what weight oil should I try?
It shifts great and is quiet when the tach is above 1500-1600 rpm. Thinking about trying a 5-20 synthetic. But I am waiting to hear from the experts on here before I do anything,
I don't want to go through something like I did on the Autolite GP deal.
on
1 Post
Don't put anything other than ATF in it. A good full synthetic ATF is probably the best you could do for it. Do you have a solid flywheel or the original dual mass flywheel? If you have a solid flywheel, then the noise you hear is gear rollover, and there is really nothing you can do about it. If you have the original dual mass, I suggest getting it out of there ASAP!
I will add a couple of quarts of ATF and see what happens.
Thanks
JesterPgh
02-02-2009 08:04 PM
nikwave
09-14-2008 07:15 AM
