Welding in Wrap Around window 58 F100
Old 05-01-2014, 07:55 PM
jenkinsj's Avatar
jenkinsj
jenkinsj is offline
Hello,
Any ideas or suggestions on welding in a wrap around window from one 58 cab to another.
Will I need to brace the back panel of the cab if I cut the extra metal out of the receiving truck?
Thanks.
Jack
Old 05-03-2014, 03:07 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Yes....make sure the truck is sitting straight & level (assuming the cab is on the truck), then weld in (or bolt in if you can make that work) bracing to ensure the cab doesn't move, twist & stays in place during the process.
Old 05-03-2014, 07:35 PM
jenkinsj's Avatar
jenkinsj
jenkinsj is offline
bracing
like make an x brace across the back of the cab what will distort the most?
Old 05-04-2014, 04:48 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
what IMHO you have most to worry about is the twisting of the cab....and cutting the corners is right where the structural integraty is...if the frame of the truck is supported against movement & level/square, then there is much less of an issue and then you would want to support against minor unexpected movement when the corners are cut.
Old 05-04-2014, 08:44 PM
jenkinsj's Avatar
jenkinsj
jenkinsj is offline
cab
Got it thanks.
BullDog58
03-06-2017 03:55 PM
alsop
11-07-2016 11:08 PM
manlikesford
01-18-2013 01:17 AM
dozer72
04-22-2011 10:54 PM
Bushwacker
06-21-2000 09:18 PM
Quick Reply: Welding in Wrap Around window 58 F100
