odd dull vibration/rattle 05 F150 - Ford Truck Enthusiasts Forums
Old 05-01-2014, 07:47 PM
tsunami23 tsunami23 is offline
tsunami23 is starting off with a positive reputation.
I'm kind of a newbie on this site,and haven't posted very much,but I could use some help.
I have a strange dull sounding rattle/vibration in my 2005 F150 4wd with the 5.4 engine,and automatic trans.
I can't really explain it but it feels sort of like a dull sounding (not metallic) Rattle or vibration,that seems mostly up front.It kind of feels like I'm driving on a mildly rough road.
Try to imagine the dull heavy sound made by a bunch of hard rubber ***** rattling around in a wooden box.
It happens mostly when I'm at a constant speed like 35-45 mph with no acceleration or deceleration.,just a straight speed.It also seems to increase a tiny bit when slowing down to a stop.
I feel it mostly in the seat,and forward.,only a tiny bit in the steering wheel.
I had the transmission pan dropped and filter changed,the fluid was nice and clean,with no metal particles.and It shifts fine.
I thought it may be the universal joints so when I was at the dealer for an oil change he had a tech look at it and said it needed u-joints.They gave me a price of $600.00,naturally I didn't have them do it.
I took it to a very reputable front end shop who told me the u-joints were fine,he dropped the drive shaft to inspect them and found them to be ok.
I jacked it up spun the front wheels thinking it may have been a bad hub,but no noise,all seemed fine.The engine idles fine with no vibration,and is fine at higher rpms as well
The truck has 87,000 on it,and this problem started just a few days ago.
The front end shop was at a loss for what it could be.I hear everything from broken fins in the torque converter to a bad harmonic balancer.on the motor.
It's driving me nuts,and I have to make a 1,000.00 mile trip,but this worries me.
Any thoughts,or insight on what it could be would be very much appreciated.
Thanks guys
Old 05-01-2014, 09:05 PM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
Does it do this after it shifts into od?, or will it do it with od off also?.
Old 05-02-2014, 03:10 PM
Quote:
It does it no matter if its in or out on the overdrive. Funny thing is that when I just started the engine,a few minutes ago, it was running rough, like it was missfiring, and I had it in park. I increased the rpms a bit and it shook more. This was the first time I felt any difference in the engine.So, once I started driving, it was doing the same as it did before with the vibration? When I stopped at a light the engine seemed to idle fine..
I stopped the truck, put it in park, and brought the rpms up to1500 and tried keeping it there, but I noticed that the rpms would drop very slowly, and then increase very slowly back to 1500
I'm wondering if its a missfire in the engine that gets worse under a load.
Im at a loss with this,it bringing into a shop to have them look at it on monday
Front driveline play bigb56 1999 - 2003 7.3L Power Stroke Diesel 3 04-26-2016 10:34 PM
02 F350 Driveline Vibration after Clutch Replacement drus136566 1999 to 2016 Super Duty 1 03-28-2015 08:23 PM
02 7.3 EX Vibration Atc210 Excursion - King of SUVs 125 12-01-2012 03:50 PM
vibration at 45-55 mph the78ranger 1999 - 2003 7.3L Power Stroke Diesel 5 07-16-2012 06:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
