rough hp estimate - Ford Truck Enthusiasts Forums
rough hp estimate
Old 05-01-2014, 05:33 PM
boss3024mesoon boss3024mesoon is offline
boss3024mesoon is starting off with a positive reputation.
rough hp estimate
hi im ted a new member. i am restoring a 85 f150. sandblasted frame, all new everything underneath. i did up a 351 windsor(86 block, 69heads) i must mention that i was on a tight budget when i did heads . spent to much and could have bought a am set instead. oh well . i am happy with them .
030 over ,stock crank and rods (good rod bolts)
balanced rotating
kb flats (9.8 to 1 comp.)
comp cam 456/456 dur 268
weiland stealth
heads- ported, 3 angle ,all comp componants, manley valves ,
i need a carb. (suggestions)
rebuilt c6 , 3 55 2500 stall converter.
Old 05-01-2014, 06:32 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
About 300hp.
Old 05-01-2014, 08:56 PM
thanks bva. i should mention i have roller tip rocks and i port matched heads and intake. what i could do is sell heads and buy better. i have botttom end for moree. cam ifffy
Old 05-02-2014, 09:11 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
What are the full cam specs? I can do a dyno sim of it but I'd be guessing about the heads and my guess is those heads don't even flow 200cfm. You would definitely gain from aftermarket heads.
Old 05-04-2014, 07:40 AM
The Comp cam in the 300 I'm building now has the same lift and duration.
So yeah, a set of AFR heads would probably give you another 50+hp. But you wouldn't notice much difference below 4,000-5,000 rpm. How often do you flog it past 5,000 rpm?
I'm partial to Edelbrock carbs because they generally run right out-of-the-box, are simple and easy to tune if needed. Unless you're spanking it a 600cfm is plenty.
Old 06-16-2014, 02:23 PM
POPAJON POPAJON is online now
POPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud ofPOPAJON has much to be proud of
Paul, I am over here in Cranbrook Ontario. I have a favour to ask of you. Would you do a dyno simulation for me? I can send you the engine details here or in a PM. John
Old 06-18-2014, 08:09 AM
Conanski's Avatar
Yeah send me a PM with the details.
Old 07-02-2014, 12:25 AM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is offline
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
Quote:
Hey con, if I give you the full specs on my engine could you run a sim for me? I'm estimating It makes around 330-350 hp and somewhere around 400lb-ft. But don't have any real clue.
My 400 build SDDL-UP 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 92 11-08-2015 03:45 AM
whats the best performance cam for 460's? i.e. comp,lunati,howards etc CRUNKED77FORD Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 06-28-2015 01:52 PM
Rear end gears F250 BBpwer 1973 - 1979 F-100 & Larger F-Series Trucks 4 05-03-2015 08:46 PM
DiMora's 400 build - part deux dimora 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 175 04-04-2015 03:48 AM
300 six hp and torque possibilities fomocoguy3 Ford Inline Six, 200, 250, 4.9L / 300 95 04-04-2014 07:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
