Meet the Team Behind the 2015 Ford F-Series Super Duty, May 1-May 16, 2014
#136
Power Stroke Vs. Navistar V-8
Navistar has a video out that compares the 6.7 to Navistar's V-8. Major issue is Ford's use of Aluminum heads vs. Navistar's CI and alleged superior strength of Navistar's bottom end vs. Ford's choice of cross bolted mains.
Your version?
Your version?
#137
We spoke to Greg and Dave about these:
The axles used for the 2015 F-250 and SRW F-350 are the same.
John, we know you're very interested in this based on some of your previous posts. We have different horsepower and torque ratings for the F-250 and F-350 6.2-liter V8 due to different test procedures used for the different gross vehicle weight ratings of each truck. Engine output for both the F-250 and F-350 is the same, it's just that the rating is different because of the GVWR. Let us know if you have more questions about this.
Thank you! The team regularly reviews customer and field feedback on engine drivability and transmission shift quality. Calibration refinements have been made based on customer feed-back to address shift and engagement feel.
This has been a complete turn around and you all have stepped up to the plate and we're grateful for your candid responses.
Keep up the great work and like we said from the beginning, we thank you all for your participation on FTE. It's making my decision to look toward another Super Duty for a replacement vehicle in the near future a lot easier.
#138
Good answers to the questions that got answered. With today almost over I assume since we have not heard if the the Q&A was extended that it is done and the remaining questions and new ones won't be answered.
I would like the Q&A to be extended, since there are lots of good questions that have not been answered or mentioned of a place to find the info.
Please continue to answer our questions.
#139
Received 3,991 Likes
on
Job is NOT Finished.........
Keep Going...........
In other words: "Damn the Torpedos, Full speed ahead"
#140
Received 5,158 Likes
on
#141
I give credit where credit is due and for their recent endeavors, the Ford team deserves a round of applause! The answers in this round seemed much more candid and informative. I look forward to the next round of answers.
#143
on
Really.......Good question !!
#144
There is ferrous materials, stainless steel, and other material types in the design. The HPFP system runs ~30,000psi so materials are chosen primarily for durability and multiple fuel types compatibility. The system is such that microns of metallic particles could cause failures depending on the source so effectiveness of magnets is not feasible/efficient.
I have been curious about this 30,000psi in the pump and fuel rails and injectors. 30,000psi is way beyond ignition/detonation levels, what happens when an air bubble enters the system/pump and ignites?
We have seen oil pumps destruct on race cars (high rpm) because of foaming oil and detonation in the pump itself. It happens not from the little 80-100psi of oil but in the area between the intake and exhaust ports of the pump where there is no where for the oil to go and pressures skyrocket. Tiny bit of air and boom oil pump disintegrates. We would chalk it up to bad pumps but there is a tell tale sign of black soot from detonation in the pump housing itself. Changing to a (less) nonfoaming oil and better crank case evacuation help alleviate the problem.
But the same idea has me wondering if some of the HPFP failures are because of this very same thing. Foaming diesel fuel is pretty common and even with the best of systems it is almost guarantied at some point air is going to go threw the system.
Personally I would feel much better with a lower fuel pressure and then have the injectors do the work.
#145
I agree, and there are injectors that are unit electro piezo injection injectors, that drive from the camshaft, and still deliver high pressures needed to meet emissions, BUT, they don't allow injections on the exhaust stroke, and they are a lot bigger.
#146
GOOD NEWS!
This Q&A is going to be extended!
Ford has been gracious enough to extend their visit with us and considering this past Friday's answers, I'm stoked about this coming Friday!!
Keep the questions coming and let's make this thread and Ford's presence here worthwhile for all involved.
#149
Hello. Thanks for coming on here to talk with everyone. My question might not fit in here, but it's as close as I'll get to talking to someone who might be able to answer. I have owned 3 superdutys and one excursion. I need the cab room of the excursion, but the capabilities of the truck. So my question is, is there a chance of ever getting a bigger cab like, dare I say, the megacab? Even f150's cab is bigger than the superduty. I'm looking to get my fourth superduty, but the cab size of the megacab is drawing me in. I've been trying to hold off, so is it pipe dream of mine, or is one in the works that I can wait for?
Thanks
Clarence.
Thanks
Clarence.
#150
I saw this question asked already, and I would like to know more as well...what has been done to increase roll over protection on the 2015 Super Duty? And in general, what has been done to increase safety and crash protection in the 2015 Super Duty?
