That sounds good.. I worked on the Miata a little today. It had a slight leak by the thermostat hose connection. I tightened the clamp and I think that fixed it.
I didn't notice it even when I checked my oil.. It was cool then and I guess the fluid would evaporate over night.. I will just have to keep an eye on it for a while..
Sometimes you can just miss things like that. I have done it more than once. The system is under pressure when hot. So as it cooled the coolant that leaked could have evaporated. It probably wouldn't leak when cool.
