05 Supercrew 4x4 with a squealing front end - Ford Truck Enthusiasts Forums
Old 04-30-2014, 11:19 PM
Schiben Schiben is offline
Schiben is starting off with a positive reputation.
My 05 Supercrew with 172k miles started making a horrible noise these last couple days. It sounds like its coming from the front passenger side area. The best I can describe is that it sounds like an electric tool motor with bad bearings. I'll be driving along at 45mph or above and every now and then I'll hear a really bad bearing squeal. It's bad enough that I can feel the extra friction caused by the squeal start to slow my truck down. It's vehicle speed related. I know what a bad wheel bearing sounds like and this is nothing like that. It's gotten bad enough I'm nervous to drive anywhere. Any pointers out there?
Old 05-01-2014, 10:01 PM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
What do the rotors look like? Chances are its a bad wheel bearing, but could also be dragging brakes.
Old 05-01-2014, 10:53 PM
I doubt it's brakes. While the truck was moving and making the noise I applied the brakes and the sound was the same. I'm wondering if it has to do with bearings somewhere in the front axle area.
Old 05-01-2014, 11:53 PM
steelhead2's Avatar
Gotta be a hub bearing going out.
Old 05-02-2014, 09:45 PM
VTX1800N1 VTX1800N1 is offline
VTX1800N1 is starting off with a positive reputation.
Unplug the electrical connector for the IWE solenoid. It's on the firewall behind the battery. Drive it again and see if the noise is still there.
http://www.f150forum.com/f72/how-dia...72/?styleid=14
V10 Engine Squeal ljs05 Excursion - King of SUVs 3 10-10-2016 06:27 PM
Bypassing ac Dank Hill 1987 - 1996 F150 & Larger F-Series Trucks 11 04-25-2016 03:32 PM
Squealing noise in torque Converter at 3000 rpm Vette1003 1997 - 2003 F150 1 04-10-2016 08:43 AM
Water pump replacment Joe19 1997 - 2003 F150 2 11-02-2015 11:11 AM
My truck is squealing like a stuck pig Lady Syren Ranger & B-Series 14 10-09-2004 09:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
