What axles shafts can i use?
hello I recently bought a posi centersection with a different gear ratio for my truck at a swap meet. my truck is a 71 F100 with the ford 9". the problem is my Axles are 28 spline(I did not know this until I pulled an Axle shaft) and the centersection I bought is 31 spline. so basically im wondering what years can I use that will have the same length axle shafts and are 31 spline? or will I need to order this aftermarket? any information at all would be great! thank you!
Dentside axles won't work because their rear track is two inches wider.
I recall Currie Enterprises offers cut-to-fit axles.
For general information purposes...:
OutsideWidth Year Model
56.50 1969-1977 Maverick 8"
57.00 1974-1978 Mustang II 8"
57.25 1957-1959 Ford, Ranchero, Station Wagon
57.25 1965-1966 Mustang
58.00 1966-1977 Bronco
58.00 1964-1965 Falcon
58.00 1977-1981 Granada/Versailles
58.50 1977-1981 Versailles
59.25 1967-1970 Mustang, Fairlane, Comet, Cougar
60.00 1967 Cougar
60.00 1958-1960 Edsel
61.00 1964-1971 Ford Full Size
61.00 1949-1951 Mercury
61.25 1957-1972 Ford F-100 Pickup
61.25 1960-1964 Ford Full Size
61.25 1971-1973 Mustang
61.25 1967-1973 Torino, Ranchero, Fairlane
63.00 1970-1979 Ranchero & Torino
63.00 1972-1979 Ford Full Size & Intermediate
63.50 1967 Fairlane (Coil Springs)
65.25 1973-1986 Ford F-150 Pickup
65.25 1978-1986 Bronco
65.25 1973-1986 Ford Van 3/4 Ton
68.00 1972 Ford Van 3/4 Ton
69.25 1977-1986 Ford E-150 Van
Pic: Column Left - Lines 14 & 15
C8TZ-4234-A = 28 Spline Axle Shaft / Right/Left is the same / Obsolete
1968/72 F100 w/9"
C8TZ-4234-B .. 31 Spine Axle Shaft / Right/Left is the same / Obsolete
1968/72 F100 with WDM-H - WDM-J - WDM-AH - WDM-AJ 9" rear axles & 1968/72 F100 with WEY & WFF 9" rear axles with a 9 3/8" ring gear.
Passenger Car & Bronco 9" rear axles are right and left specific.
1968/72 F100 w/9"
71mach351
11-02-2014 08:21 PM
FLN
09-22-2013 11:29 AM
70 LIGHTNING
06-16-2012 08:28 AM
pat57woods
08-10-2009 12:03 PM
