Difficult to find replacement carb spacer
Hey guys... Still fighting with my truck and am looking for a carb rebuild kit. I bought a new carb to intake spacer as well as a spacer to intake. The gasket has a hole in it for something, but the new gaskets hole doesn't line up. Does anyone have any idea why? Here is the gasket that came off.
I put it back on because the hole on the new one covered about half of the hole in the intake. I'm having a lot of hunting issues with this truck at low RPM. It runs great above 1500 RPM, anything below and the hunting will eventually kill the engine. I've been trying to find vacuum leaks.
I was able to get the vacuum to about 15 at idle. It fluctuates 1-2 at an idle of about 1200. If I lower the idle, the hunting gets worse and worse until it dies.
You don't think this gasket could be an issue?
It's a cast iron intake, and I've determined (hopefully) that it's a 2150. It has the choke pulldown/dashpot, the heat activated choke assembly that comes off the manifold, but doesn't have any tags or markings on the carb.
What carb was supposed to come on this truck? I'm pretty certain the engine is a replacement, the transmission is a hell of a lot older than the truck (thanks NumberDummy for helping figure that out).
It looks like I forgot to take a picture while I had it all tore apart. I removed the EGR valve completely and bolted down a plate in its place as the valve was failed and blocked off by the PO. I wouldn't be surprised if there was more EGR systems elsewhere....
1983/85 F100/350 & Bronco 302/351W with cast iron 2V intake manifold.
E5HZ-9C477-A (replaced D7FZ-9C477-A) .. THICK Gasket-Carburetor to EGR Spacer Plate (Motorcraft CG-539-A) / Obsolete
1980/85 E/F100/350 & Bronco 302/351W with cast iron 2V intake manifold.
1977/79 LTD II (not an LTD!)/Granada/Monarch/Versailles/Thunderbird/Cougar/Ranchero 302/351W // 1977/80 Mustang/Pinto/Bobcat 2.8L V6 // 1978/79 Fairmont/Zephyr 302.
1979/80 LTD/Grand Marquis 302/351W w/cast iron intake manifold // 1980 Granada/Monarch/Versailles 302 // 1980/81 Thunderbird/Cougar 302 w/cast iron intake manifold.
Both gaskets available from auto parts stores.
As Bill pointed out and as I thought that spacer plate is the EGR and you are showing 1 of 2 gaskets, looks to be the thick one?
If you are not using the EGR then if you only can get a gasket that blocks it off so what?
As long as it seals the carb & EGR ports you are good to go in my book.
Dave ----
Dave ----
jctruax
07-03-2012 05:25 AM
Inlinetorque
02-10-2011 03:05 AM
wiznewski
09-09-2003 09:28 AM
