My Experience With an H-Pipe - Ford Truck Enthusiasts Forums
Old 04-30-2014, 06:55 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is online now
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
After running a true dual exhaust system (a separate exhaust pipe running from each header) since about 2009, a friend in the exhaust business convinced me to install a crossover pipe, or "H-pipe" between the two exhaust pipes. It was explained to me that the H-pipe would help with low end torque (and an X-pipe would help with top end horsepower). So I went ahead and did it, not expecting much difference.
Let me just say that the H-pipe made a VERY noticeable difference in my truck! Driving away, I felt the difference immediately. Although throttle response was always excellent with this truck, the H-pipe greatly improved low end power; I can actually feel the difference in the throttle. The engine seems to "breathe" better, as in I can accelerate MUCH easier and faster with less throttle pressure than before. The improvement feels like I fixed a sticking brake, or like I shed 500 pounds off the truck!
An added bonus came after I got home and got out to inspect the H-pipe location with the truck at idle: the exhaust note is now much deeper, much STRONGER. It now sounds like...a 5.0 Mustang!
The Fonz is happy!
Old 04-30-2014, 07:55 PM
RL250's Avatar
RL250 RL250 is offline
O/O Desert Rat Customs
RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.
Got any pictures? Maybe a video? Glad it works well for you.
Old 04-30-2014, 09:10 PM
5280's Avatar
5280 5280 is offline
5280 is gaining momentum as a positive member of FTE.
Interesting. Thanks for posting this. Both of my exhaust pipes run down the passenger side, very close to each other. I wonder if there would be any advantage to using the "H" with the pipes in this configurations?
Old 04-30-2014, 09:54 PM
ctubutis's Avatar
ctubutis ctubutis is online now
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
I wonder if my Magnaflow two-in, two-out muffler has that built-in or not.
Old 04-30-2014, 09:58 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Ford's do well with an h or crossover pipe, something about the firing order IIRC. The scavenging needs to be done closer to the front, more around the bellhousing. An old trick was to paint an area a couple feet long closer to the engine on each pipe, where the paint burned off was the hot spot and the pipe would go between there.
Old 04-30-2014, 10:03 PM
RL250's Avatar
Quote:
If it's the same one I bought, it has a built in X pipe.
Old 04-30-2014, 10:08 PM
LARIAT 85's Avatar
Quote:
Sorry, I don't.
I really wasn't expecting any sort of gain, and I decided to do it on a whim. Otherwise, I would have.
Quote:
My exhaust pipes route the same way. The H-pipe was welded in between the transmission and the [Flowmaster] mufflers, on the passenger's side right past the door. I am running dual exhaust with a separate muffler on each pipe.
It was explained to me that the H-pipe helps with low-end torque and produces a deeper, classic muscle car sound. The X-pipe helps more on top end horsepower and produces a raspier, modern exotic car sound.
Which sound do YOU like best?
Old 04-30-2014, 10:18 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
I want to do this on dad's truck. I suspect that 390 will respond quite well.....
Old 05-01-2014, 12:46 AM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
I've got a Y pipe in my 2 in 1 out muffler. MASSIVE increase in power and torque over true dual glasspack home made system.
2.5" dual in to muffler 3" single outlet with hooker long tube headers.
Old 05-01-2014, 07:32 AM
RL250's Avatar
I'll be running Flowtech longtube headers to a side by side dual to a dual in/dual out MagnaFlow 22" muffler with a built in cross over. I'm going to exit the same spot as the FE truck, passenger side behind the cab. No cats. I don't think an H pipe will help me as much, simply because there is not a lot of room for it. I'm going to have to have my DS tube cross under the tailshaft of the transmission to dump where I want it. When I get the motor going I am going to take it in for a quote and ideas on where to run everything.
Old 05-01-2014, 09:20 AM
SVTDriver97's Avatar
SVTDriver97 SVTDriver97 is offline
SVTDriver97 is gaining momentum as a positive member of FTE.
This guy put an H-pipe on his F250, and it sounds like a Mustang!
Pretty slick!
Old 05-06-2014, 12:43 AM
ludafisk ludafisk is offline
ludafisk is starting off with a positive reputation.
Quote:
Revving it up - YouTube
That sounds pretty close to my truck, but cleaner and a bit deeper.
I'm running stock manifolds and y-pipe to a Magnaflow muffler with a turnout in front of the rear wheel. It was a hack hob for the mounting and turnout.
Was thinking of scraping the whole system for headers and duals. Now considering some headers and new y-pipe. Or maybe X-pipe into current muffler. It's a pretty big can and might work.
Old 05-06-2014, 03:23 AM
I'm glad I just spent the money on the exhaust system, lifetime warranty and it was done nicely. It sounds slightly different now at idle. I have it running on manifold vacuum now instead of ported, it sounds faster and even cleaner now.
Old 05-06-2014, 05:59 PM
loner-dwp's Avatar
loner-dwp loner-dwp is offline
loner-dwp is starting off with a positive reputation.
I never realized the difference in exhaust note, H pipe compared to X pipe.
For the guys that do have X or H pipes on their trucks, does anyone have any pics of underneath. Just curious to see where you placed them.
H-PIPE INSTALL NOTES RAY1986F150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 01-29-2013 03:56 PM
Exhaust sleep_deprived129 1967 - 1972 F-100 & Larger F-Series Trucks 1 11-15-2011 09:13 PM
Can I Put H-Pipe on askintc Exhaust Systems 10 11-19-2008 05:32 PM
shorty question turbo69 1978 - 1996 Big Bronco 5 01-25-2005 02:31 AM
do i need a H-pipe Stokes Exhaust Systems 2 07-03-2003 04:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
