6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Water in Fuel (nothing comes out) & Wrench Symbol
Old 05-04-2014, 11:10 AM
BroncoEx's Avatar
BroncoEx
BroncoEx is offline
I had the same problem. Take a look at my thread. This cleared it up.
https://www.ford-trucks.com/forums/1...n-my-hfcm.html
Messy, but very inexpensive.
Tim
Old 05-04-2014, 02:52 PM
Tawn's Avatar
Tawn
Tawn is offline
Tim
Thanks Tim,
The filters have been changed at 10K since new - the HFCM has not been drained as recommended. The dealer said they cleaned out the HFCM last week - it's back at the dealer now and I should know more Monday afternoon. I will let ya'll know what I find out.
Old 05-05-2014, 07:54 PM
Tawn's Avatar
Tawn
Tawn is offline
Back from the dealer for the second time. They found more gunk in the water separator. Cleaned it out, codes all cleared and it seems to be running fine now. They said it was not in limp mode when it wouldn't get out of it's own way - they said not enough fuel was getting through the separator - basically fuel starvation.
Tomorrow I am hooking up my 10,000+ lbs boat and pulling it a little over 100 miles, we will see if the problem is really taken care of.
Old 05-05-2014, 08:00 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
drain upon arrival. Drain again in a few days.
If it flows well then you may have gotten it all out now.
Lesson learned. Regular draining will help to prevent the gunk.
Old 05-05-2014, 08:05 PM
Tawn's Avatar
Tawn
Tawn is offline
Will do!
Thanks again.
Old 05-06-2014, 08:28 PM
Tawn's Avatar
Tawn
Tawn is offline
200 mile round trip, 100 of it pulling 11,000 lbs boat and no further problems. I got lucky!!
Old 05-06-2014, 08:44 PM
senix's Avatar
senix
senix is online now
congrats!!
Old 05-07-2014, 09:43 AM
wp6529's Avatar
wp6529
wp6529 is offline
The important thing is to determine what the gunk is/was. There are two very different issues I'm aware of:
1. Parafin separation - This seems to show as waxy globs forming in the water sump of the HFCM. They will clog the drain valve and if bad enough can block the WIF sensor so you don't get an alarm if you do get water buildup. The fix for this is to open and clean the HFCM if you find the drain isn't flowing at a normal rate.
2. Bacterial growth - This shows as slimy gunk on the outside of the HFCM filter and can restrict fuel flow. The fix for this is to "shock" the fuel tank with a good dose of diesel biocide such as Power Service Bio-Kleen (small bottle of expensive toxic stuff). If you have this issue you will need to check and service your HFCM filter on a short cycle until the dead bacteria gunk is gone.
The key thing here is that issue 1 just happens sometimes and you can't do much of anything to prevent it, while issue 2 once it occurs is likely to continue to occur until you kill off the supply of bacteria in the tank.
Old 05-07-2014, 10:43 PM
fordfish's Avatar
fordfish
fordfish is offline
I can crack the banjo bolts. Are the rubber washers reusable ?
Old 05-08-2014, 05:17 AM
senix's Avatar
senix
senix is online now
yeah, just crack them open and see what you get.
Old 05-09-2014, 11:04 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM
BROWN DOG KTM is offline
Originally Posted by wp6529
... The fix for this is to open and clean the HFCM .
Listen to this guy
Draining helps, but it don't get all of the contamination out
You'll be surprised how much crud is inside.
Old 05-10-2014, 07:46 AM
wp6529's Avatar
wp6529
wp6529 is offline
Originally Posted by BROWN DOG KTM
Listen to this guy
Or how little. I had a case where the drain was clogged by a pea sized blop of parafin, and there were two others like it in the sump. I've also seen pictures of sumps completely full of parafin.
It would seem the parafin precipitation may be related to water in the fuel since it seems to only occur in the water sump. I rarely see any water when I drain my separator, perhaps a few pinhead sized drops which may explain why I also don't see much parafin precipitation.
Possibly those with heavily clogged sumps are in areas where for whatever reason they see more water in fuel / tank condensation or something.
  #28
Old 05-11-2014, 08:14 AM
weyland426's Avatar
weyland426
weyland426 is offline
Had my truck in the shop no less than 10 times in a years time for water sep/wrench indicator/limp mode issues only to eventually find out I had a malformed fuel tank that was letting rain water in around the top...$1200 replacement. Funny that it wasn't found until I was out of warranty
  #29
Old 05-11-2014, 02:02 PM
wp6529's Avatar
wp6529
wp6529 is offline
If you were at the dealer multiple times for the same complaint and what was clearly a manufacturing defect was found later out of warranty then Ford *should* cover it since the problem was reported in warranty and the fact that their trained technicians took so long to find the manufacturing defect cause is their fault, not yours. If I were you I'd ping Ford and ask about it.
A/Ox4
08-14-2011 08:55 AM
jdamato1
24
04-21-2010 11:53 AM
Diesel Daddy
08-13-2006 10:06 PM
puffer
12-16-2005 03:17 AM
truszip
03-08-2004 05:45 PM
Quick Reply: Water in Fuel (nothing comes out) & Wrench Symbol
