Ford 390 Cam help - Ford Truck Enthusiasts Forums
Ford 390 Cam help
Old 04-30-2014, 03:50 PM
GaRedneck91 GaRedneck91 is offline
GaRedneck91 is starting off with a positive reputation.
Ford 390 Cam help
My rig is a 75 ford f100 had the 360 which is being took out and rebuilt and converted to the 390. I'm swapping the old intake for the edelbrock performer and the carb for a holley 750. Money allowing headers soon .. Got 3:50 gears and 33x12.50x15 m/t . I use my truck for everything from huntin to hittin mud holes to just crusin to haulin scrap or whatever I need it for. I would like a good soundin cam but really I want one that's gonna work best with my setup.. Also it's a 4speed with the granny gear . Any help would be appreciated
Old 07-13-2014, 10:51 PM
RLWEST RLWEST is offline
RLWEST is starting off with a positive reputation.
Holy mackerel - a cam question and you didn't already get 50 responses?? A Comp H.E. 268 or 270 Magnum should work well. They're both older designs, pretty easy on the valvetrain while still working pretty darn well. I'm running the 268 in a 390 with automatic and 3.00/1 gears, and it works pretty well. It has a slight lope at idle; the 270 will give you a nastier idle, with a resultant loss of some low-end, but the manual tranny will help you out there.
Old 08-14-2014, 10:01 PM
ivaf100 ivaf100 is offline
ivaf100 is starting off with a positive reputation.
I agree on the 270 with a manual transmission should work just fine. You might want to rethink about headers though. Most FE headers I have seen are to close to the starter causing problems with all the heat plus the header has to be removed to change the starter. Sanderson is the only one I've heard about that doesn't cause problems with the starter but, they are expensive.
Old 08-29-2014, 08:37 PM
Ford FE guy Ford FE guy is offline
Ford FE guy is starting off with a positive reputation.
<p><p>There are a lot of guys over at the FE power forums that could help you out. Header clearance is an issue, I would recommend a power master mini. Header wise I like the Doug's stuff personally. Camshaft wise, unless you change the intake and do some head work you really should stay rather mild. The truck engines ran much lower compression than the car versions and the heads were rather restrictive.</p></p>
Old 09-02-2014, 12:42 AM
tjnthesky tjnthesky is offline
tjnthesky is starting off with a positive reputation.
Hot Headers
I have had great luck with a little welding modifications to the headers, but the starter needs a heat shield and insulation. However a mild cam and headers will cause some performance changes to your low end. It depends how you drive and your usual RPM range. Thanks
What size carb on 390 Dot Heton FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 04-16-2016 12:27 AM
F100 Camshaft Recommendations wanted crazy96863 1973 - 1979 F-100 & Larger F-Series Trucks 15 02-24-2016 03:25 PM
55mph turning 4000rpms? GaRedneck91 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 22 01-14-2015 10:17 AM
Cam recommendations on 390 GaRedneck91 1973 - 1979 F-100 & Larger F-Series Trucks 58 06-14-2014 07:10 PM
390 cam jakedevore 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-27-2012 03:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
