Are manual transmissions things of the past for Ford Trucks? - Page 23 - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
  #331
Old 05-03-2016, 11:02 PM
JKBrad's Avatar
JKBrad JKBrad is online now
JKBrad has a great reputation on FTE.JKBrad has a great reputation on FTE.JKBrad has a great reputation on FTE.JKBrad has a great reputation on FTE.
Quote:
Originally Posted by madpogue View Post
Ahem ZF5/ZF6 cough!
Understood I should have clarified in an F150. Thought it was a given since we're in an F150 forum here, but you'll never know who'll drop in.
On a side note, I bought a brand new GMC 1500 extended cab in 1994 that came from the factory with an NV4500! Crazy. It had a TBI 350 and a 3.08 rear end. The granny would get anything I needed to pull going and the OD gave me 18 mpg on the highway. I got a great deal on it because nobody wanted it. I think it was a special order that someone backed out on. I've only ever seen one other like it.
  #332
Old 05-04-2016, 03:09 PM
jedijeb jedijeb is offline
jedijeb is starting off with a positive reputation.
Quote:
Originally Posted by Kapusta View Post
My 63 F100 had a 3 on the tree. I actually liked it because there was no floor shifter in the way to slide in to the drivers seat from the passenger side.
I think all the "extra" gears in transmissions are overrated. You really only need 4; 3 forward gears and one for reverse. One to get going, one for passing, one for crusing and one to back up for what ever falls off the truck.
That's all you need! In my 96 F150 I normally only use 1 3 and 5 when driving, don't really need 2 or 4 unless taking off on a steep hill or pulling a heavy load.
When I first got the 96 with the M5 OD back in 96 I hauled about 2500 pounds of tobacco 60 miles to market in the bed of the truck up and down hills on curvy roads, I figure if that didn't break it then any normal usage for a half ton truck should be ok, and so far it has worked just fine for 250k miles. What normally kills them is if the seal at the top where the shifter mounts drys out and leaks and it blows the oil out. The other thing is people trying to tow heavy trailers when they have 2:73 or 3:08 gears in it, just puts too much strain on the transmission.
  #333
Old 05-04-2016, 03:44 PM
Kapusta's Avatar
Kapusta Kapusta is offline
Kapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to all
I have a feeling my truck was used for some heavy towing and it may have had a bed mounted camper at some point. It has a stout frame mounted hitch and air shocks in the rear.
  #334
Old 05-04-2016, 03:58 PM
Dakster's Avatar
Dakster Dakster is online now
Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.Dakster has a spectacular reputation.
It used to be, back in the day, that manuals had more power and got better mileage. Or at least you could make them as efficient as you wanted.
Always liked having absolute control.
  #335
Old 05-04-2016, 06:46 PM
Kapusta's Avatar
Agreed. I like to control the truck and not the truck controlling me. I think I could still get a manual transmission equipped truck get better mileage than a similarly equipped automatic.
  #336
Old 05-04-2016, 08:07 PM
Pgh Rebel's Avatar
Pgh Rebel Pgh Rebel is offline
Pgh Rebel is gaining momentum as a positive member of FTE.Pgh Rebel is gaining momentum as a positive member of FTE.
I think the heaviest load I ever had in my 2006 was about 1300-1400 lbs of mulch. With 3.55's out back it handled it fine and I hardly knew it was back there, except on the steepest of hills, when it wanted to bog down a bit. If I'm running empty, I can routinely take off in 2nd if I'm on level ground. Been doing that for 10 years, it never hurt the clutch a bit. If I'm taking off uphill, then just to be safe I will go into 1st. I have jumped gears, but I don't usually do that while I'm driving. I try to drive it as gently as possible, unless I really need to get on it. If treated properly, the M5OD is as stout as it needs to be. Remember, it's a 1/2 ton truck not a Superduty!
  #337
Old 05-04-2016, 11:03 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
Quote:
Originally Posted by Pgh Rebel View Post
Nice Chevy Russ! Do you get a chance to put the top down much up there in Alaska?
We get some great days, these last 3 summers have had so many record breaking days it's been great. Which is good since we have two convertibles.
  #338
Old 05-04-2016, 11:37 PM
Pgh Rebel's Avatar
Dang that Olds is a big ol car! Sure looks sweet though
  #339
Old 02-05-2017, 04:16 PM
Methano Methano is offline
Methano is starting off with a positive reputation.
Cool Manual transmissions still common
You just have to leave the USA to find manual transmissions still outnumber automatics. My friends in Colombia laughed when I asked if they drove automatics. They had never owned an automatic. I too have never owned an automatic transmission, and never plan to buy a vehicle that has one. Winter driving, off road driving, and mountain braking are only a few of the reasons I would never feel safe in an automatic.
  #340
Old 02-05-2017, 06:11 PM
Frdtrkrul Frdtrkrul is offline
Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.
Quote:
That's outside of North America and isn't surprising. It's because modern automatics get the same mpg or slightly better mpg over manuals, as well a lot of people do not want to learn them. Another factor is not every manual is the same, as far as where the clutch engages, so it's a learning curve for most. Top of that, some engines are detuned, like the Cummins turbo diesel, mostly because of the clutch.
The only trucks that still come with a manual are Tacoma, Frontier and the Colorado/Canyon I believe. It's possible but unlikely, the new Ranger may come with one but I wouldn't hold my breath and I'm just guessing. Considering this thread is also over a year old, I wouldn't expect many more replies.
  #341
Old 02-05-2017, 06:18 PM
GlueGuy's Avatar
GlueGuy GlueGuy is online now
GlueGuy has a good reputation on FTE.GlueGuy has a good reputation on FTE.
At some point, at least in North America, it will become more expensive to have a manual transmission. Simply because of the small production numbers.
  #342
Old 02-07-2017, 09:26 AM
"the new Ranger may come with one but I wouldn't hold my breath" Actually if you want a new Ranger with a manual transmission, or perhaps a diesel and a manual transmission, all you have to do is cross the border to Mexico. Getting it imported to the US might land you in jail, but Ford does sell manual transmissions in trucks in Mexico. Glimpse of the Future? Check out this Ford Ranger from the 2016 Overland Expo - The Fast Lane Truck
The reasons given for manuals not being offered are pure BS. The real reason is US regulation. CAFE standards make it undesirable for a US auto manufacturer to sell manual transmissions and so they have eliminated them, and seem to have convinced all of you that it is because no one wants them.
I just ordered a new Tacoma with a manual. Of course, I had to order it built. They would not sell me one without preordering it. I could care less about the cost, because I know that over the years, with my driving style, the manual will get better fuel economy and is safer to drive, as well as being much more adept off road than an automatic.
  #343
Old 02-07-2017, 07:13 PM
Pgh Rebel's Avatar
Many people I know either do not know how to drive a manual and have no interest in learning; or they know how to drive it but still have no interest in owning one. We as buyers must realize two things: the automakers cannot build the vehicles we want, they can only build what the federal government and the EPA will allow them to build; the second thing is that those of us Americans who still prefer a manual transmission are a dying breed. Go to any city or suburb and talk to someone who spends 3 hours of their day sitting in rush hour traffic and ask them if they want to fool with a clutch pedal. More than likely the answer will be a resounding NO!
  #344
Old 02-07-2017, 09:14 PM
GlueGuy's Avatar
Well, there's that. We do consider our manual transmission vehicles as having built-in anti-theft devices. The flip side is when you go someplace with alleged "valet parking", and the parking droid can't drive the vehicle?!? It's alternately hilarious and depressing! :-
  #345
Old 02-07-2017, 11:38 PM
brokenleg brokenleg is online now
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
Pretty much the truth. Ive driven sticks for years myself. but they are hard to find and most people dont want to have a stick. and they are not cheaper to maintain anymore either.
2008 F-250sd convert to manual transmission Frozen001 1999 to 2016 Super Duty 12 10-04-2016 08:14 AM
Manual Transmission 4X4? MBDiagMan 1997 - 2003 F150 23 08-26-2016 12:25 PM
Absurd no manual transmission kel1306 1999 to 2016 Super Duty 97 02-09-2016 02:01 PM
5 Speed Transmission Issue/Question GeorgePBurdell Ranger & B-Series 7 07-29-2015 08:37 AM
Manual downshifting in drive D macguy 6.7L Power Stroke Diesel 3 08-08-2012 06:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
