Are manual transmissions things of the past for Ford Trucks? - Page 18 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2015+ F150
Sign In
Register Forgot Password?
2015+ F150 Discuss the 2015 Ford F150 SPONSORED BY:
  #256
Old 05-31-2015, 11:08 PM
QwkTrip's Avatar
QwkTrip QwkTrip is offline
QwkTrip has a great reputation on FTE.QwkTrip has a great reputation on FTE.QwkTrip has a great reputation on FTE.QwkTrip has a great reputation on FTE.QwkTrip has a great reputation on FTE.QwkTrip has a great reputation on FTE.
First car I ever drove was a manual. First car I ever bought was a manual. First diesel truck I had was a manual. I have always had at least one vehicle with a manual all my driving years.
I wouldn't get a manual in my truck for anything. Modern auto transmissions are AWESOME! I have a manual in my hotrod for a little variety, but even that trans is highly customized to work well and frankly just to live.
  #257
Old 05-31-2015, 11:46 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
Quote:
Originally Posted by Frdtrkrul View Post
think the best ones I've heard that are butter would be the NV5600 behind 24 valve Cummins.
No. If you're converting put a ZF6 behind a Cummins. The NV5600s are heavy, clunky, and mechanically unsound. First gear and reverse gear shield the rear main bearing from oil on those transmissions unless you modify the gears to pump oil through. The easy fix is to overfill by two quarts, but that drags down efficiency. They also have reverse on the wrong side. On a truck it should always be IN & UP. To allow for easy rocking between the lowest gear and a numerically similar reverse.
__________________
2008 F-250 XL 5.4L Reg. Cab 4x2 6-spd 4.10 w/B&W "Turnoverball"
OE Options installed: TowCommand Brake controller, Upgraded to 4 spkr. Single CD/AM/FM w/AUX from 2 spkr. AM/FM, cab clearance lights, Fog Lights, Cruise Control, Redundant Audio Controls.
  #258
Old 06-01-2015, 12:53 AM
Frdtrkrul Frdtrkrul is offline
Frdtrkrul is gaining momentum as a positive member of FTE.
McSniperliger McSniperliger
ZF6s are few and far between unless cheap bay has them. Not sure how running the cooling system will be on it since don't they connect with the radiator or do they run their own cooler upfront? Cause I still may yet do a Cummins swap and I would like to have a manual with it, rather than dink around with controllers and would like to teach my ol lady how to drive a manual just cause.
__________________
-History is written by the victor, history is filled with liars.
-1999 F150 5.4L V8 auto XLT Ext. Cab long bed 260,000 miles Bridgestone Dueler Revo 2 265/75/16
-Ford Today, Ford Tomorrow, Ford FOREVER!
  #259
Old 06-01-2015, 02:42 AM
Idont want a newF150 Idont want a newF150 is offline
Idont want a newF150 is starting off with a positive reputation.
Quote:
Originally Posted by jedijeb View Post
I guess all the truck manufacturers have lost me as a customer from now on, since I won't buy a new truck with an automatic.
I second that. Back in the good old days, when rangers (were still available), 4x2 V6 F-150's and super duty's still had sticks, I would sometimes go to the Ford website, and build a truck exactly the way I wanted it, and think that one day (i was a teen then), that I would go to their website, order a truck exactly the way I wanted it, and go pick it up from the local Ford dealership.
These days, I am an adult and work at a Ford dealership, and could pick up a brand new truck at a price better then what 99% of the people here could get one for...but as it is today, there is nothing new on the lot that I would buy.
And if lack of a stick isnt a big enough turn-off, just look at the price of these new trucks. At my dealership, the 2015 F-150's are about $55K, but if you want to "upgrade" (AKA pay way more then all the extra ***** they add to it) to an FTX/Black Ops edition, then you are looking at around $80K, $25K more for a lift, fancy tires, and leather seats, oh and dont forget the fancy plastic and FAKE air scoops on the hood which only make tight turns harder as they block your view around the hood.
My ranger has 210K+ miles on it and needs work, my F-250 is 31 years old, has 250K+ miles, and needs a frame-off restoration, and my 83 F-150 just sits in the back of our dealership because I bought it on impulse and dont really have the time or money to work on it with the two other trucks I have, but that is fine with me, if one truck *****s out on me, I can use the other until the first is fixed. And that is unfortunately what we will have to do if we still want to drive a truck with a stick, buy an older one and learn how to fix everything on it. Which would you rather work on, a 6.9 IDI or a 6.7 PSD?
  #260
Old 06-01-2015, 08:33 AM
madpogue madpogue is offline
madpogue has a great reputation on FTE.madpogue has a great reputation on FTE.madpogue has a great reputation on FTE.madpogue has a great reputation on FTE.madpogue has a great reputation on FTE.
Quote:
Originally Posted by Idont want a newF150 View Post
...FTX/Black Ops edition, then you are looking at around $80K...
Interesting choice for the model name, in that you'd have to have a "black budget" to afford one. Shoot, that's more than we paid for our house....
  #261
Old 06-01-2015, 08:43 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
A 6.7PSD any day of the week....
__________________
Chris - Avid Winter Hater
2007 F-250 XLT 4x4 CC SB 6.0 PSD - ARP, IPR Gen2 EGR Delete, 4" turbo-back, no muffler, no cat, 6.4 banjo bolts, SCT X3, EA 270A Alt, coolant filter, air bags, Ranchos, etc.
1994 Mustang GT - HCI, Novi2k blower, MM suspension parts, etc
Hope & A Prayer Motorsports
  #262
Old 06-01-2015, 08:47 AM
Not 100% accurate. Ram trucks in the 2500/3500 still offer the Cummins 6.7L with the G56 6 speed manual transmission, you just won't get getting the 865lb/ft of torque instead its 660. You can varify it yourselves for ram trucks. Least its still an option in the 2015 MY maybe 2016.
__________________
  #263
Old 06-01-2015, 09:08 AM
TexasRebel's Avatar
You can find ZF6s all over the place. Both GM and Ford used them in their pickups.
You can likely make up cooler lines for any radiator with a transmission cooler and get by. If you need something else, an external cooler would work, too.
...also, you can always find them somewhere... ZF Friedrichshafen - ZF Friedrichshafen AG
__________________
  #264
Old 06-01-2015, 04:29 PM
RigTrash601's Avatar
RigTrash601 RigTrash601 is offline
Non Compus Mentis
RigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputationRigTrash601 has a superb reputation
Mitch Thornhill RigTrash601
Quote:
Black Ops edition is a customized truck by Tuscany, the hood scoops look "cheesy" and they way overcharge for the lift, tires, etc....
__________________
Mitch...
2014 F250 6.7L PSD,Platinum 4x4, White, Pecan Leather, FX4 package. H&S, S&B, 4" Flo-Pro Full Delete. 4" - 4 Link BDS Lift Fox 2.0 Shocks / Dual Steering Stabilizer Fuel Rampage 20x10 w / 35x12.5x20 Toyo MT'sRIP Charles Glen Thornhill Sr. Feb. 07 1943 / Oct. 25 2014.... I Miss You Pop!
[SIGPIC][/SIGPIC]
  #265
Old 06-01-2015, 10:15 PM
I've heard never get the GM version of the ZF6 because they did something odd to them that made them not work as well as the Ford versions. Just comparing here hows the old ZF5 to the newer ZF6? Shifting wise and how they are overall?
__________________
  #266
Old 06-02-2015, 04:40 PM
TexasRebel's Avatar
The Ford and GM versions are the same transmission, but spline differences and bell housings make them incompatible. If you are customizing... pick the easier one.
I've never driven a ZF5.
Muncie 4 spd. <- 197x C10
T98 <- Jeep
NV4500 <- 5 speed New Venture in a 2002 GM
ZF6 <- Multiple Fords. V8, V10, 7.3, 6.0
M62 <- Yep, 3 on the tree
...I thought this list was going to be shorter... There are other Jeeps, a Festiva... just too many.
__________________
  #267
Old 06-08-2015, 12:49 PM
GlueGuy's Avatar
GlueGuy GlueGuy is online now
GlueGuy is starting off with a positive reputation.
Now have about 150 miles on our new XLT (supercrew/6-1/2' box), and have driven it on a pretty wide mix of roads and conditions.
Part of one of our town/home routes brings us up a mountain road from ~~ 400' elevation to ~~ 2400' elevation over about 6 miles. It is windy, and the speed limit is 30-35 (some places 15).
Overall, the auto-magic did pretty well; especially around town and on the freeway. However, coming up the mountain road, the auto-magic lost its gusto. It wanted to keep up-shifting to 4, and then dropping to 3 or 2 when the steepness went up. In effect, it was "hunting" and it didn't do so well. I found that as I tried to compensate for the increasing steepness of the road, that it would have to suddenly downshift, and we ended up "surging" until I had to back off the throttle. No fun.
So I switched to manual mode, and it did much better with me just holding it in 3rd, except for the flatter straight aways. No more surges, and overall a much smoother experience.
YMMV.
__________________
bp
2005 Tundra Access Cab
2008 Tacoma Access Cab
2010 Tacoma Crew Cab
2012 Tacoma Access Cab
2015 F-150 Crew Cab XLT 3.5EB 4x4
Similar Threads
tranny wont shift to manual 1 mmunhollon21 1999 - 2003 7.3L Power Stroke Diesel 5 09-14-2014 09:58 AM
Manual or Automatic Transmission? Stevaroo01 1987 - 1996 F150 & Larger F-Series Trucks 21 08-23-2014 12:50 PM
2008 F-250sd convert to manual transmission Frozen001 Super Duty & Heavy Duty 11 08-18-2014 11:01 PM
Manual Transmissions ?? 69 F-350 Wrecker General Diesel Discussion 89 08-11-2014 05:19 PM
94 F150 Manual Transmission trowlmannmbr1 Clutch, Transmission, Differential, Axle & Transfer Case 5 03-20-2003 11:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
