2009 F150 Fan Blower no response
Started up today and no response from the A/C fan on any speed- dual climate control. Checked all fuses good. Electronic control panel shows normal with all the fan speeds, but no blower motor action.
Is it the motor or a resistor/controller? Thought with a bad resistor you would get the fan on at least in one speed.
Any ideas? Thanks
Any ideas? Thanks
You should get the fan at HIGH speed. Full 12v. High speed bypasses the resistor.
You can unplug the fan connector and check for voltage at the fan.
Put it on high speed, Pull fan connector, check for voltage. If no voltage the problem is elsewhere.
The fan connector can be reached under the passenger side. Pc of cake.
The resistor connector is behind the glove box. Held on by two blue screws
There was no fan at high speed or any other speed setting. Replaced the resistor, very easy, as described above, thanks However, I replaced it again a month later with same symptoms and another time about a month ago. Now its dead again- 3 resistors in less than 6 months- no fan speed on any setting. Any ideas what is burning out the resistors?
Ford F150 A/C Blower Resistor
I had the same issue, just stopped blowing! we had some cooler days and didn't need the AC so didn't notice, then a Hot one and NO Fan, When driving fast, the air that was pushed into the cab was COLD but no fan.
Finally found link to A/C Blower Resistor and Purchased the part from local dealer for $67+ tax ....
Part# 9l3z-19e624-b
Part# YH-1827
Followed video I found on youtube:
Stan
2011 Ford F150 w/43000 miles
3.5L EcoBoost
Part# 9l3z-19e624-b
Part# YH-1827
Stan
3.5L EcoBoost
Yeti
1999 to 2016 Super Duty
10-28-2002 11:09 PM
