a strange brake problem: 04 new body F-150 - Ford Truck Enthusiasts Forums
Old 04-29-2014, 08:14 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
one of the neighborhood kids stopped by this afternoon with his 04 new body style 4 door short bed 5.4 powered 4X4 F-150.
he was complaining about "spongy" brakes and asked if i could look at it.
i felt the back rotors and knew it needed back brakes, so went to napa and picked up pads and rotors.
the driver side rear pads were seized in the bracket
i was able to pry the caliper off, and had to use a hammer to knock the pads off.
i put the new stainless sliders/shims on the bracket, and the pads would not go on.
the only way i could get the pads to fit was if i removed the upper slider/shim.
the passenger side fit fine with both slider/shims on the bracket.
anyone ever see this before?
a little history on the truck, his brother in law bought it new, and it was front/rear smashed at 6 months old with 1200 miles on it.
body shop replaced the nose and bed.
he got it 4 years ago with 21,000 miles on it after his brother in law passed away, it now has 113,000 miles on it.
he never had rear brakes put on it, and i really doubt his brother in law had them done either.
i am thinking the rear axle brake bracket was bent in the accident and the body shop never fixed it.
Old 05-02-2014, 09:58 PM
VTX1800N1 VTX1800N1 is offline
VTX1800N1 is starting off with a positive reputation.
The pads should hook into the caliper carrier at the rear. A spring on the forward edge of the pad compresses as it's installed in the carrier. The caliper then slides over both.
Old 05-03-2014, 08:03 AM
i ain't rite
i know this. i am talking about the stainless steel slider that goes over the cast caliper mount that the pads sit on.
Old 05-03-2014, 08:38 AM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
I had the same problem with my Napa parts. Initially I reassembled without using the sliders. That caused a rattle I didn't like listening to, so I disassembled the calipers again and filed down the channel for the slider. It took a few tries but I got it to fit correctly. Now it all works the way it should
Need Brake Hlelp/Advice RobRoss Excursion - King of SUVs 13 05-29-2015 09:13 AM
2001 Expedition passenger side brake pad wear indicator position? BaitGuru Expedition & Navigator 4 01-20-2015 07:53 PM
Brake issue??? ROBBINthaHOOD 6.0L Power Stroke Diesel 3 12-29-2014 08:30 PM
broke track bar mount again ??? sand_fiend 1999 - 2003 7.3L Power Stroke Diesel 6 04-20-2014 02:20 PM
Question on replacing front brake pad and rotors. jjlrrw 1997 - 2003 F150 7 06-05-2008 10:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
