Tailgate accidently locks?
MY '97 did that, first you'll have to remove the plate on the inside and manually unlock it and/or pull the bars to open it. Once that is done you'll need to play with the lock and see what is happening. I ended up putting a dab of RTV on the lock so it wouldn't fall into the lock position, bad thing is you won't be locking it if you do that.
Can't remember what size torx bolts that plate is held on with, probably 20 or 25.
My '01, the '06 and now even the '11 did that. As suggested, take that cover off then spray the linkage well from end to end with a good penetrating lubricant (NOT WD40, it's useless). That should take care of the problem. If you look at the linkage at the lock, you will see a piece that slides, mostly by gravity. If it doesn't slide easily it will actually lock the tailgate. Yeah, I know that sounds like poor engineering, and is IMO, but it is what it is. And my fix - given me by a Ford dealership mech.
A Caution!!! When you remove the cover, just barely loosen the 10 or so machine screws then spray them with a penetrating oil, letting it wick in for a minute or so. You can easily strip the threads if there is any dirt or corrosion as I found out
So basically "It's my party and I'll cry if I want to, cry if I want to! You would cry too if it happened to youuuu." Another witty response.
When I ask a legitimate question and get a response such as you made, I'll make a comeback statement that you may not appreciate.
Sean_Memphis
06-07-2014 11:13 PM
TexasGuy001
27
10-04-2010 02:57 AM
