power steering question
Old 04-29-2014, 04:07 PM
kirbykoon's Avatar
kirbykoon
kirbykoon is offline
My 1992 f150 4x4 started leaking power steering fluid, so after trying all the easy ways to replace the seal at the pitman arm(input shaft) I had to take the steering box out completely.Than I had to take the shaft out of the steering box via the sector shaft cover to get a screwdriver behind the seal to pop it out,here is my question,,,does the shaft have to go back in a certain way or can i just put it back in as it came out? does it have to line up to other gear a certain way?
Old 04-29-2014, 07:25 PM
SteelHorse4x4's Avatar
SteelHorse4x4
SteelHorse4x4 is offline
When you put it back together make sure you get 4 full turns stop to stop. Then center it, make sure wheels are straight when you put pitman arm bac on and you should be good.
Old 04-29-2014, 10:18 PM
kirbykoon's Avatar
kirbykoon
4 full turns on the shaft that goes to the steering column or 4 full turns on the pitman arm shaft? please excuse my ignorance.and thank you so much for the reply
Old 04-30-2014, 06:22 AM
SteelHorse4x4
4 turns on the steering shaft, 2 each way from center. might take some playing with to get just right again, but not too bad.
Old 04-30-2014, 06:46 PM
kirbykoon's Avatar
kirbykoon
SteelHorse, I just wanted to thank you for your help, I tried the 4 full turns,but was only able to get a little better than 2 complete turns, so I took the steering box back apart and found that I did not line the sector shaft up correctly when i took it apart to put the seal in.I lined it up and than did the 4 turns and everything fell right into place. Thankyou very very much
Hankster1958
10-07-2013 04:03 PM
rbsample
02-21-2012 11:15 PM
monkei
02-27-2004 04:21 AM
jetjock16
1999 to 2016 Super Duty
58
07-17-2003 07:34 PM
Quick Reply: power steering question
