power steering bracket
Have a 1973 F250 , 390/C6/4.11
When bolting on the power steering adjusment bracket that fastens directly to the engine, noticed the pulley is offset about 3/4" from the crankshaft pulley.
Looks like the power steering unit is driven directly from the crankshaft pulley and no contact with fan pulley.
There are two sheeves on the crankshaft pulley, one for the fan and one for the power steering unit
This truck is a barn yard find and probably has been farmitized.
The fan pulley has only one sheeve that runs the alternator.
The alternator belt lines up perfectly.
This there supposed to be some major spacers between the power steering bracket and the two water pump casting mounting holes and one
engine block hole?
engine block hole?
Have a 1973 F250 390/C6.
When bolting on the power steering bracket noticed the pulley is offset about 3/4" from the crankshaft pulley.
There are two sheaves on the crankshaft pulley, one for the fan and one for the power steering unit.
Harmonic balancer contains a single sheave pulley. FoMoCo offered single, double and triple sheave outer accessory pulleys that bolt to the balancer to add P/S, A/C, dual belt alternators.
On the non A/C power steering bracket that bolts to the 390 engine.
The pulley configuration is:
1. fan pulley- one sheeve
2. alternator pulley- one sheeve
3. crankshaft pulley- two sheeves with space between the two sheeves.
Made two aluminum spacers 1" dia X .800" long that fit to the water pump and one aluminum spacer 1" dia X 1.150" long that fits against the engine block. The three spacers have 3/8" diameter through holes. The spacers were machined on a horizontal lathe.
As a result of using these spacers with grade 8 bolts, the power steering pulley has perfect alignment with the outer crankshaft sheeve.
Do not know if this setup is identical to the original factory setup,
since the power steering assembly was missing some OE parts.
The photos posted by mikeoOoOoO was a big help, since it established that the correct crankshaft pulley was installed on the engine.
Here's a clearer picture of the stock crankshaft pulley for a non-A/C truck with power steering.
SC'79
17
02-19-2014 01:05 PM
Craig5_12
07-08-2006 07:32 PM
