They were on a junk yard 460 I bought. I think it came out of a 4x4, it had a rear sump pan on it. I might put them on Ebay so I was wondering just what all trucks they were used on. One of those things one hates to throw in the junk, someone might need them.
Those look like car mounts I've taken off before.
Our efi 4x4 trucks use a heavy duty isolator with 2 studs into the frame mount. It uses the 4 bolts to hold it to the block. Not sure if the 2wd is the same, but that bracket only allows the rubber isolator only two bolts to that bracket.
