Delayed, rough start 96 F250 351W
It's alive!
Re checked the ignition and it seems like I missed something last time around
When I took the cap off I noticed the rotor pickup (the springy thing in the middle) had a fair amount of corrosion on it. I cleaned it with a brass brush.
Then I started it on the rear tank. It started much faster then before but still had to crank for a few seconds and it stumbles a little. I drove it around a little and it is much better then before, but still past 60% throttle or so it cuts out and bogs.
Here's a weird thing:
I re-checked the fuel pressure with the truck at idle and it was a steady 30-32 on front and rear tanks.
Man this truck has me stumped!! and angry...
Since replacing the cap and rotor she ran better for 2 or so weeks. Still took forever to start and it was cutting out and stuttering hard after 40-50% throttle. Then it completely died on me at an intersection and I had to push it into a parking lot!
I found that I was getting no spark at the coil so using the test light method and a Haynes manual I figured out it was the ICM. I had previously replaced this 5 months ago with a cheap Standard Motor Products one (it was black) so I figured whatever is really wrong is taxing the ICM more then normal.
So being the cheapskate I am I went and bought one from autozone that has a lifetime warranty . Installed it and the truck starts fast and smooth and idles nice and if you drive it immediately it runs well but less then a minute later it will start to cut out and bog after 50% throttle and it gets worse as time goes by. Hard starting after its warm, but when you come back it will start nicely and do the same thing as before.
What could this be? I have no codes besides 111, and the fuel pressure is a steady 32 at idle. I have tested the coil. Timing is at 12 degrees.
Please help! Its getting cold and riding my motorcycle sucks! haha
Haha thanks for the support slingsaws, kind of disheartening to hear you resorted to carbing the truck!
Funny you mention that though, all of my carbed engines run GREAT!
I have read about people pulling the PCM and inspecting the inside of it. I'm going to do this when I get home tonight.
Yea money is tight here too. I've read a few posts where people have spent 500-1000$ on diagnostics from a repair shop just to replace the reccommended part and still have the same problem. Screw that!
Where you live do you have to do emmision testing? How did your 93' carbbed truck pass?
I have also tried unplugging the MAP sensor and it made no difference.
1993TEALFORDEXPLORER
02-18-2016 06:54 AM
86Stepside
19
10-12-2015 08:43 PM
TazDude69
10-16-2014 12:29 PM
hutch1973
07-22-2006 09:03 PM
