Supercab cab corners - Ford Truck Enthusiasts Forums
Old 04-28-2014, 08:19 PM
kadrocker kadrocker is offline
kadrocker is starting off with a positive reputation.
I need to do some bodywork. Are all replacement cab corners the same? Supercab corners aren't different, are they?
Finally getting around to fixing some rust on my 76 F150 supercab!
Old 04-28-2014, 08:41 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
By different, they are much longer from door pillar all the way back.
Old 04-28-2014, 10:12 PM
march's Avatar
march march is offline
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
LMC sells two different panels; a 5 1/2 inch wide version for reg cab and a 28 inch wide version for supercab. But if you only need a few inches for repair, I would think the profiles are the same.
Old 04-29-2014, 09:07 AM
GLR's Avatar
GLR GLR is offline
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
I'd check our sponsors first. For example:
Ford Truck CAB CORNER REAR REPAIR RH | F-40300-13R1 | NPD
Old 04-29-2014, 06:06 PM
brian1080's Avatar
brian1080 brian1080 is offline
brian1080 has a good reputation on FTE.brian1080 has a good reputation on FTE.
So, I found a supercab cab at a salvage yard... 1320stang 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-21-2016 05:21 PM
Ford superduty doors and rockers szotty Ford Truck Parts for Sale 0 08-03-2014 10:40 AM
cab corners/inner cab corners eviljmizfit 1987 - 1996 F150 & Larger F-Series Trucks 10 03-18-2014 01:12 PM
Rocker patch panels? RKraft Excursion - King of SUVs 9 02-02-2014 09:19 PM
1978 f250 supercab darkpurp1e 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-25-2012 04:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
