Re-wiring with EZ wire kit on my 52
Old 04-28-2014, 08:02 PM
tractormanbill's Avatar
tractormanbill
tractormanbill is offline
tractorman
Using a 21 circuit EZ wiring kit and I am in the finishing stages of re-wiring my 52 complete with AC with trinary switch, electric fan & relay, electric fuel pump radio, turn signals, etc.
I am keeping the 6 volt dash gages with a voltage converter.
I didn't like the rear wiring running on the floor so I came out the firewall, down and inside the frame to get to the rear.
I am pretty good at automotive electrical and wiring but would never have finished a re-wire without the kit with all the additional items that were original on the truck.
It is a little daunting when you first start but by taking the sections and going one wire at a time it will come around.
Their tech help could not be better. When you call you talk to the man that makes the units and he knows every wire, it's color and where it goes off of the top of his head.
Will keep you informed.
TractormanBill
Old 04-28-2014, 08:14 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,833 Likes on 1,833 Posts
I use the same harness in my truck. I installed it several years ago and haven't had any issues with it at all.
The biggest tip I can make is to not cut any wire or make any termination until you are absolutely satisfied with the routing of it. On my truck I ended up routing the wires several different ways until I was satisfied with the layout (I'm glad I didn't make the final cuts/terminations until the very end)
Good luck, you'll be on the road in no time at all
Bobby
Old 04-29-2014, 12:51 AM
smallello's Avatar
smallello
smallello is offline
I used the same one on my truck.
I took my time with it, didn't rush any part of it and it went pretty smooth.
I am very happy with it overall.
Old 04-29-2014, 01:09 AM
geoffthepilot's Avatar
geoffthepilot
geoffthepilot is offline
I did the same to my truck. only I used the cheaper off brand. saved a few dollars. total mistake. it was such a head ache. It worked out in the end but took way more time than it could have. I recommend to all that are doing this to not cheap out on the wiring kit.
Old 04-29-2014, 08:22 AM
49willard's Avatar
49willard
49willard is offline
Bill,
I had a similar experience with EZ wiring in my 49. I also kept the stock gauges. I chose to hide a lot of my wiring so I came into the engine bay down low on the drivers side by the cab corner.
Old 04-29-2014, 10:01 AM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Thanks for the info Bill. I have been looking at different options for wiring and appreciate hearing others experiences.
Old 04-29-2014, 05:40 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Originally Posted by 49willard
Bill,
I wanted to keep the firewall clean too. I brought my wires out down low on the passenger side.
Bobby
NewClimber
08-04-2019 09:22 PM
65fordguy
12-14-2013 03:52 PM
okstatef150
2004 - 2008 F150
04-16-2012 11:20 PM
Greenford100
03-29-2011 11:58 AM
snipa
19
03-01-2005 09:10 PM
Quick Reply: Re-wiring with EZ wire kit on my 52
