What kind of 5er/TT/trailer do you pull with your 6.7?
#1396
Received 3,985 Likes
on
Justin, I have had more tire trouble on my towed utility trailers than I have had on my two FW toyhaulers. I had two blow outs on my previous toyhauler on my way to get six new tires. The problem was the age. Certainly toyhaulers are heavier and carry more weight than other FW's. In my experience the key to tires is proper load range, proper air pressure and age. Maintain the proper air pressure and replace tires every four or five years regardless of the tread wear.
#1397
I agree. I've been looking at a bunch of fivers that are '10-'12 range and when you tell the seller that in the offer price you need to account for 1k$ for tires after checking the date stamps they think you're crazy cause there's lots of tread
#1398
Hmmmm... Maybe something recent or local to you...
I checked with the NTB not far from my town and they quoted me $165 plus $20 shipping for each tire as they were special order. Simpletire.com was $159 and $90 for shipping (6)..
I will check with them again when I replace the spare..
#1399
Just catching up on this thread. To those discussing the 2" to 2.5" adapter. I'd bag it and just come up with the money for a 2.5" shank. Lining up the adapter is a pain especially with a heavy hitch and as some said, it can warp. On my last truck I had upgraded to the Reese Titan which was a 2.5 receiver. That stupid adapter made me crazy. It was loose and always slid way in when I was trying to line up the shank. I bought a 2.5" shank and was so much happier. They make 2.5" ball mounts for your smaller hitching needs as well.
#1400
On the 2.5" vs. 2.0" receiver, I haven't had any issues with the adaptor except when I forgot to replace the pin and I lost it a year ago. But it is a PITA when you are trying to attach a heavy item to the hitch and the darn adaptor keeps sliding in. Mine slides way too easy but I keep the receiver greased and pull the hitch out when I'm not using it. I also keep a plug in it to keep the dirt, grit and salt out as much as possible. I learned my lesson on a Toyota Tundra the wife had that she left the ball in all the time. Needed to pull it out after a few years and it took a ten pound sledge and a lot of Breakfree to finally get it out. Rust had welded it in pretty good.
#1401
#1402
on
#1403
#1404
#1405
Based on my recent purchase I think your estimate may be a bit high.
Last Nov. I replaced five tires = out the door for under $800. They too all looked good, including the one that popped while turning/ backing up.
#1408
#1409
