Hyduralic Lash adjusters Question - Ford Truck Enthusiasts Forums
Old 04-27-2014, 10:04 PM
Ford'05HG's Avatar
Ford'05HG Ford'05HG is offline
Ford'05HG is gaining momentum as a positive member of FTE.Ford'05HG is gaining momentum as a positive member of FTE.
Howdy Guys! I have a 2005 Ex with the 5.4 3v. Just 2 months ago I rebuilt all the timing like phasers, chains, solenoids, and the phasers cause they were really starting to annoy me. Couldn't hear over the engine at the drive thru.
I did the oil pump an all exterior gaskets. But while I was in there I noticed a rocker had seized and got kicked during a time I was pulling 4000 rpms. So I didn't exactly know how to change the rocker out then so I just left it without one since it was and intake valve and it still had another one.
A week or two ago I read these motors use hydraulic lash adjusters and it got me thinking, because I didn't remove the adjuster just the rocker, that maybe I should've put one in there because the oil might be losing pressure due to this open adjuster. What do you guys think?
Old 04-29-2014, 01:29 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
It's probably not a major issue, but I would reinstall the rocker. You should be able to loosen the cam bolts a bit to reinstall it.
Old 04-29-2014, 02:26 PM
Ford'05HG's Avatar
I decide not to to do it also in part to the fact that it filed the cam lobe down to the point where its probably useless in that spot. So I just figure there was no point in putting one in.
Old 05-01-2014, 10:52 PM
je5 je5 is offline
je5 is starting off with a positive reputation.
Did the metal come out in the filter?
Old 05-02-2014, 01:23 AM
Ford'05HG's Avatar
I actually don't do the oil changes myself so I cant say if it did it not.
2004 F-150 FX4 5.4l Triton Loud Exhaust Leak from Top of Engine? GCosta 2004 - 2008 F150 6 02-05-2016 11:32 AM
2005 Expedition Still Seeking Wisdom deucecoop 1997-2006 Expedition & Navigator 0 01-22-2015 08:53 AM
Difference between 04 lash adjusters and 05-up lash adjusters?? shaw4825 2004 - 2008 F150 1 01-21-2015 12:03 PM
292 Y-Block has never really run right wfon 1961 - 1966 F-100 & Larger F-Series Trucks 10 10-08-2014 07:45 PM
Need Help. P0012, Im stumped nlaao03 Modular V8 (4.6L, 5.4L) 5 09-21-2012 09:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
