cab mounts
Old 04-27-2014, 08:09 PM
jtlinn1975's Avatar
jtlinn1975
jtlinn1975 is offline
cab mounts
This maybe a dumb question, but thought I would ask anyways. Can I replace the front cab mounts on my 69 without taking off the cab?
Old 04-27-2014, 08:48 PM
maverick600's Avatar
maverick600
maverick600 is offline
I have been told that yes you can. I need the same thing done to mine as well....hopefully you can get some answers as to how.
Old 04-27-2014, 09:24 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
Me too. My driver side front is shot.
Old 05-02-2014, 07:08 AM
Copper67440's Avatar
Copper67440
Copper67440 is offline
Bump. Need to do them on my 68. Inquiring minds need to know.
Old 05-02-2014, 08:20 AM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
Yessir you can replace the floor pan and front cab mounts while cab is still on the frame. I've done it to my truck. Take front 2 cab mount bolts out jack up the front of the cab just enough to give yourself working room. I used some wood blocks cut to length to stick under the rocker area to hold the cab up. Make sure to measure and re measure multiple times on cab mount placement. so you can get the new ones in same place as the originals were.
Old 05-02-2014, 08:23 PM
whiskey runner's Avatar
whiskey runner
whiskey runner is offline
i changed my cab mounts and floorboard sections at the same time.. it is best to leave the cab on the frame to get everything aligned back up and tacked together..then you can pull the cab to make it easier to weld them up if you like.. the aftermarket mounts i got were not exactly like original.. but seemed to of worked out good, the floor sections worked well after some trimming to just match the areas i needed to replace.. of you look at my threads you will see mine being replaced
Old 05-02-2014, 08:28 PM
whiskey runner
i dont know if this is right.. drug out the old 71
Old 05-02-2014, 11:26 PM
jtlinn1975's Avatar
jtlinn1975
I assume I will need to take the front clip off to lift up the cab.
Old 05-03-2014, 12:03 AM
orich's Avatar
orich
orich is offline
Go with the cheap soft metal ones like LMC and DC NPD for like $29 bucks others and in 3 yrs this is what you'll end up with.. You get what you pay for when it comes to these cheap mounts.
Buy the better ons about 90 bucks each now but their more like the oem ones.
orich
Old 05-03-2014, 12:10 AM
orich's Avatar
orich
orich is offline
these were a pain to install anyway yeah 29 bucks and look at it..
Sorry the double pix
orich
Old 05-03-2014, 09:04 AM
crazed87bronco
Yea take the hood,inner and outer fenders off and cab bolts and you will be able to lift the front of the cab up. have enough room to do the cab mounts.
Old 05-03-2014, 09:10 AM
crazed87bronco
orich
Whatever you do be sure to take our advise on cheap mounts. It sucks orich I put Lmc mounts in my truck and acouple months later is when the thread came out about just how ****ty those LMC mounts are. Haven't drove my truck yet so they didn't start to crack...who all carries the good cab mounts now? Haven't looked at any of the sheet metal distributors lately on our trucks.
Old 05-03-2014, 03:39 PM
flyboy2610's Avatar
flyboy2610
flyboy2610 is offline
Dennis Carpenter has them.
Cab Mounting | Dennis Carpenter Ford Restoration Parts
It appears the right side mount is the same for 65-79, but the left side changed in 68.
Old 05-03-2014, 06:49 PM
jtlinn1975's Avatar
jtlinn1975
I was looking at some from Carolina classic, or the ones from Dennis carpenters.
Old 11-20-2014, 09:02 PM
351Cleveland C4
So what is entirely involved with this. I really need to get mine done before I start having other problems.
Quick Reply: cab mounts
