Testing Oil Pressure Sending Unit
Old 06-30-2014, 05:52 PM
powells_f150's Avatar
powells_f150
powells_f150 is offline
Working with Autometer to fix a problem where my oil pressure gauge is reading to high at times, we've got it narrowed down to the sending unit. Since I couldn't find this information elsewhere, I wanted to share what their tech told me for troubleshooting the sending unit.
To check the sending unit, measure the resistance across from terminal to ground with the sending unit disconnected from the gauge. Below are the readings you should find.
0 psi 242 ohms +/- 17
25 psi 152 ohms +/- 12
50 psi 103 ohms +/- 10
75 psi 66 ohms +/- 9
100 psi 30.5 ohms +/- 5.5
Hope this helps in troubleshooting a sending unit problem.
Muchopesos
07-27-2016 05:09 PM
fubar25827
General Diesel Discussion
10-29-2010 07:53 PM
TheRoadVirus
09-07-2007 01:04 AM
MBBCop
Oil & Lubrication
01-11-2006 10:47 AM
Quick Reply: Testing Oil Pressure Sending Unit
