4.9L Hesitation..
#31
#32
I put new motorcraft plugs in and it made no difference so now I will do a pcm swap hopefully that makes a difference will keep everyone posted!!
#33
#34
#36
Sorry I haven't been updating this post, I've been under a ****load of stress lately and things are finally falling into place! Except the truck, lol. Anyways, this is what I've come up with. No vac leaks, cleaned the MAP sensor, too. I was searching around a little more and possibly I tested my EGR wrong I dunno. Anyways, was reading that the CTS could contribute to this as well. I unplugged the EGR vac line and stuck a bolt in the line to take away any vac leak there, and I also unplugged the CTS sensor. Now I don't have that miss anymore has a nice acceleration but I have no power! 3rd gear to the floor then when I hit 4th I'm to the floor and not gaining any speed! Feels like I'm towing a boat anchor behind the truck haha. Any quick ideas let me know! Regardless, I'm replacing the stupid EGR, even if it's still good which I was almost certain it is... Appreciate the time, thanks guys.
#37
#38
That's not a bad idea. I have timed it yes, I haven't rechecked it since I did it but I could. And for the fuel psi. It was about 40 psi, which was when I decided to put the new pump in. (Pump, filter, pressure regulator) Also have been running seafoam through each tank cleaning it all out.
Its*a*dads*life
03-19-2013 11:59 AM
