Need Some P/N Help
Need Some P/N Help
1966 F100 4x4 Styleside SWB 352
ND, I am trying to figure out some P/Ns for cab mount components, I was able to purchase some cab mount nos parts and I am trying to figure out if any of these will work for my truck (balance I will sell):
Upper Absorber:
-C4TZ-8100154-D (Right diameter, marked "rear", but appear too thick)
-C4TZ-8100154-B (Right diameter, marked "rear", appears to be right thickness)
-C6TZ-8100154-A (Matches LOWER Absorber, but book says it should be a 155 to be a lower not 154)
Lower Absorber:
-C5TZ-8100155A (Slightly smaller diameter than what came off from truck but is correct thickness)
-C4TZ-8100155-D (Correct diameter but too thick)
-C4TZ-8100155-C (Appears to be identical to above)
Lower Retainer:
-C4TZ-8100157-B (Smaller diameter and not threaded)
My parts book shows that a bolt and nut combination hold all of this together, but the lower retainers I took off are threaded (eliminating the need for the nut). If you guys could help figure this out it would be appreciated, if not to much of a problem I would like to know what these fit if not my truck......thanks-in-advance...m.
Upper Absorber:
Lower Absorber:
Lower Retainer:
1966 F100 4WD has coil spring front suspension, uses the same cab as 1965/66 F100/250 2WD. So the cab mounts are the same.
1965/66 F100/250 2WD & 1966 F100 4WD: 115" & 129" wheelbases.
Front & Rear cab absorbers (aka rubber insulators aka hockey pucks):
C4TZ-8100154-C .. Upper Right/Left & C4TZ-8100155-C .. Lower Right/Left
C4TZ-8100154-C replaced: C4TZ-8100154-A - C4TZ-8100154-B - C4TZ-8100154-D
C4TZ-8100155-C replaced: C4TZ-8100155-A - C4TZ-8100155-B - C4TZ-8100155-D
I'm looking for the retainer upper and lower part numbers as well. Do you have those? My cab is still on and I'm gathering everything I need to rebuild the front end this spring. So I need to confirm cab absorbers and rad support absorbers with hardward. My botls look great at the cab but the other parts screw together or something so trying to find a location with pics so I can see what is going on.
Thanks for the help, I'm pokeing around trying to put the puzzel together
ND, I beleive those part numbers are also good for a 1972 F250 4x4. Can you confirm?
Post the basic numbers of the parts you want.
Aesop
04-17-2014 06:49 PM
GVA66FordF100
04-19-2013 03:16 PM
Horsepowerdan
08-19-2007 05:49 PM
