2001 5.4L moisture in Coil on Plugs causing misfire - Ford Truck Enthusiasts Forums
Old 04-27-2014, 07:07 PM
allingeneral's Avatar
allingeneral allingeneral is offline
allingeneral is gaining momentum as a positive member of FTE.
2001 Navigator 5.4L - I had to replace one of the coils on the driver's side some time ago, and since then, I keep getting moisture under the coil cover that eventually causes a misfire. If I remove the cover and let things dry out, then the misfire goes away.
I don't drive this truck much. Where is this moisture coming from? Is it getting under the cover from outside, or is something leaking/cracked/broken internally?
Old 04-27-2014, 07:44 PM
jesse5 jesse5 is offline
jesse5 is starting off with a positive reputation.
Could be leaking intake, you did not say which cylinder or what color moisture.
Old 04-27-2014, 07:55 PM
Was cylinder #5 this time around. Will drive it for a few days while waiting for F250 6.0L parts and see if/when it happens again and try to see if it's coolant or just water.
Leaking intake? Broken/cracked or a gasket issue?
Old 04-27-2014, 08:37 PM
OK, it is up front so it should not be water leaking down from the windshield wiper cowl.
Check color and greasiness.
Could be either reason you mentioned about intake or a porous head casting.
Don't let it take out the coil drivers in the ECU. Factory manifold replacements only if cracked.
Old 04-27-2014, 09:33 PM
Thanks for the tips, jesse! reps sent.
Old 04-28-2014, 02:47 PM
je5 je5 is offline
je5 is starting off with a positive reputation.
You probably do not wash the engine or drive through enough water for the fan to spray it onto the engine do you?
If you had previous trouble around number 3 or 4 cylinders the coolant pipe or hose for the heater sometimes leaks.
Moisture Causing a Misfire? dubyaohohdee 1968-2013 Full Size Vans 10 11-01-2015 01:19 PM
V10 Knock/misfire under 2000 rpm; moisture/rain makes worse f250tritonv10 1999 to 2016 Super Duty 3 08-21-2015 11:30 AM
misfire nightmare cottonf150 1997 - 2003 F150 9 02-02-2015 10:53 PM
Misfire F-350 Went724 1999 to 2016 Super Duty 1 09-10-2014 06:53 AM
5.4 misfire cylinder 2 Okcdiscgolfer Modular V8 (4.6L, 5.4L) 9 12-28-2013 12:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
