Generator to Alternator - Ford Truck Enthusiasts Forums
Old 04-27-2014, 01:15 PM
wfon's Avatar
wfon wfon is offline
wfon is starting off with a positive reputation.
I have a 64 F100 with a 292 Y block. The generator is making some very unhappy noise. I have had it repaired before, and I have a very good local auto electronics shop to do the work, but I am considering replacing it with an alternator.
What do I need to do to make the switch besides remove the voltage regulator?
What is the correct spec for a new alternator for this engine?
Who makes a good general service unit? I use this truck, I don't need racing equipment.
Thanks.
Old 04-27-2014, 06:30 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
This was discussed fairly recently.
http://www.ford-trucks.com/forums/13...-3-wire-2.html
I think pretty much any alternator will do the job for you.
Old 04-29-2014, 11:03 AM
wfon's Avatar
Just the Pulley
It turns out the only problem with the generator was that the pulley was loose. I replaced the pulley and all is good.
Old 05-09-2014, 06:55 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
If/when you do decide to go with an alternator I recommend the Delco 10 SI.
Self regulating and plentiful. They're also very easy and cheap to service yourself.
I know, the Ford purists are gonna scream, but a superior product is just that
Alternator/generator light dimly lit once truck is started asmith6 1961 - 1966 F-100 & Larger F-Series Trucks 9 03-05-2016 06:34 AM
64 F500 Alternator Upgrade bryon.degraw 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-02-2015 06:01 PM
Alternator Problems. Help. Shutech 1999 to 2016 Super Duty 1 04-21-2015 10:31 PM
223 alternator bracket tinman52 1961 - 1966 F-100 & Larger F-Series Trucks 5 06-14-2014 10:27 PM
Generator to alternator conversion... California Codfish 1961 - 1966 F-100 & Larger F-Series Trucks 11 12-04-2012 07:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
