Lost brakes & TBC Fault
Old 04-27-2014, 10:37 AM
SniperVision's Avatar
SniperVision
SniperVision is offline
Morning,
A few minutes ago I was coming up to a stop sign & when I applied my brakes the pedal went to the floor. No brakes at all. Pedal had no pressure and went to the floor. Lucky for me I was coasting down & no one was around. My dash read TBC Fault. I put truck in neutral then back in drive and then everything was fine. When I got home I checked for codes and there were none. This was the first time it happened. Has this happened to anyone else?
Thx in advance.
Old 04-27-2014, 08:33 PM
Lx460's Avatar
Lx460
Lx460 is offline
Empty master cylinder? I'd say you have a leak. Fill it back up and see where the fluid is leaking.
If the plastic ( phenolic) pistons in the caliper crack it can leak fluid from there.
Old 04-27-2014, 08:35 PM
Lx460's Avatar
Lx460
Lx460 is offline
Tbc fault has zero to do with the pedal going dead. It only indicates a problem with trailer brake control unit itself or wiring.
If the brake! light on dash comes on it's usually low fluid in master reservoir.
Old 04-27-2014, 09:29 PM
SniperVision
I will flush tomorrow and check for leak but why would I see a tbc fault?
Old 04-30-2014, 04:01 PM
SniperVision
Bad power brake booster & bad brake master cylinder. Both had to be replaced.
Old 12-11-2018, 06:25 PM
dlynes's Avatar
dlynes
dlynes is offline
how did you determine those failed?
DBGrif91
22
10-20-2012 01:03 PM
FoPar1972
01-17-2012 05:17 PM
RTM
05-30-2005 12:23 PM
modru2004
02-15-2005 02:13 AM
Charlie01
05-26-2004 07:09 PM
Quick Reply: Lost brakes & TBC Fault
