2015 F 150 towing stability - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Old 04-26-2014, 12:04 PM
excaliber551 excaliber551 is offline
excaliber551 is starting off with a positive reputation.
Do you think the 2015 F 150 will be a much less efficient tow vehicle as the Super Crew will be 700 lbs lighter? Having a much lighter vehicle might not be the best thing to stabilize tow loads.
All things being equal the SD with it's weight advantage is a much sturdier tow platform even with the 6.2 gasser.
I was just curious what those in the know have to say on the subject.
Old 04-26-2014, 01:35 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
I'll take a wait-and-see approach on the towing. They have promised to the the real SAE towing spec starting 2015 Model year, so it's very likely that tow rating will go down anyway.
My opinion is that if you are dragging around 11,000 lbs daily, you'd be best served with the Super Duty, but for weekend warriors like me, who tow ten times a year or less, and trailers under 10,000 lbs (sometimes Waaaay under that), the F150 is a great option, and I expect the 2015 model will continue to be fully capable of this duty.
Old 04-26-2014, 07:57 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
The 2014 Silverado 1500 High Country 4x4 with the 6.2L V-8 has a max tow rating of 11,700 and a GVCWR of 17,700. The truck weighs 5429 as a crew cab with the new long box.
Both the Ram 1500 and GM 1500's are significantly lighter than the F150. I don't think that removing a few pounds will hurt much.
Old 04-27-2014, 09:52 AM
daytomann's Avatar
daytomann daytomann is offline
daytomann is starting off with a positive reputation.
uh...even at 700lbs lighter, these trucks are still heavy. If you tow anything that would cause instability in a F150, get a F250. Its it that hard to understand?
145" or 157" wheelbase best for towing? dooger54 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 15 05-31-2016 05:24 PM
2013-14 better tow vehicle than new 2015-16?? dooger54 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 8 05-05-2016 11:50 AM
2015 F250 diesel death wobble donald73d 1999 to 2016 Super Duty 16 04-22-2016 04:50 PM
F-150 To The Rescue STA-BILŪ 2009 - 2014 F150 4 02-03-2015 03:09 PM
If F150 Body Panels are Tough, Is Aluminum a problem? ncalf150 2015+ F150 9 07-23-2014 06:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
