Y block oil pump gaskets - Ford Truck Enthusiasts Forums
Old 04-25-2014, 01:59 PM
Outlaw56 Outlaw56 is offline
Outlaw56 is gaining momentum as a positive member of FTE.Outlaw56 is gaining momentum as a positive member of FTE.
Does anyone have good source for y Block oil pump gaskets? I need the gasket between the block and pump body, the gasket between the side of the oil pan and the pick up tube, and the compression gasket that goes on the end of the pick up tube where it enters the oil pump. The pump itself is working fine so I really dont want to buy a rebuild kit just to replace these gaskets.
Old 04-27-2014, 12:29 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
http://www.ebay.com/itm/B4A6710B-COAE6710B-NORS-FORD-Y-BLOCK-OIL-PAN-GASKET-SEAL-KIT-1954-62-/400689218581?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5d4af04415&vxp=mtr
Old 04-27-2014, 02:55 PM
Thanks Hiball. Looking at the photo, it looks like there are two round washers for the pan, the rest go with the oil pump (Im assuming). So looking at the two round washers on the left, one must be for the drain plug and the other one must be the fiber washer that goes on the "outside" of the oil pan where the pick up tube exits. I had read a post that talked about a copper (or brass) washer that fit on the "inside" of the oil pick up tube where it enters the oil pan.
Mine did not have a copper washer on the inside, just the fiber washer on the outside.
Is that what you have experienced as well?
Old 04-27-2014, 05:49 PM
hiball3985's Avatar
The Y block I put together last year for my 57 Ranchero had the copper washer for the inside in the gasket set. I don't recall others from years past with a fiber one on the outside.
83 f150 4.9 oil pump problem? gordo2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 08-03-2015 04:15 PM
Oil Pump to Block Gasket? BMW2 Ford Inline Six, 200, 250, 4.9L / 300 6 05-11-2014 09:28 PM
1966 ford f600 oil pump sdtrucking 1961 - 1966 F-100 & Larger F-Series Trucks 2 10-17-2012 08:37 AM
Swapping out a oil pan on 4.9 ottawaguy 1987 - 1996 F150 & Larger F-Series Trucks 23 03-22-2009 06:31 PM
95 302: Is there an oil pump gasket? brown 4x4 1987 - 1996 F150 & Larger F-Series Trucks 10 04-14-2008 10:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
