Truck stalls while driving - Ford Truck Enthusiasts Forums
Old 04-25-2014, 07:26 AM
TN Floorman TN Floorman is offline
TN Floorman is starting off with a positive reputation.
Just a little background, 2002 F-250 with the 7.3 284,000 miles. I just bought it. Doesn't seem like the PO did much other than changing oil, filters, etc. Anyway the last 2 days as I'm driving the truck will do a quick misfire like action and then it dies. I have had it do the misfire without it dying about three times, but twice it has died immediately. It won't start back up right away, but if I come back to it later, it fires right up. Changed the CPS yesterday after the first bout, and still had the problem today. After reading through several posts, I'm thinking maybe IPR, maybe even the seals on the IPR? Or maybe the fuel screen in the tank? What do you guys think? Thanks.
Old 04-25-2014, 07:31 AM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Those symptoms are pretty much exactly what a CPS dying will cause. Did you use an aftermarket or OEM sensor when you replaced it?
Old 04-25-2014, 07:46 AM
Aftermarket (hangs head in shame).
Old 04-25-2014, 07:51 AM
Pikachu's Avatar
The after market sensors have a reputation for being susceptible to RFI (radio frequency interference). Probably the best thing to do would be to pick one up at the nearest dealership and see if it cures the problem before spending time and money on other things.
Old 04-25-2014, 08:53 AM
Is there a way to test the CPS and see if that's it?
Old 04-25-2014, 09:00 AM
Pikachu's Avatar
No, not really. Sometimes it will set a soft code, but not all the time. The new sensor should only be about $30 from a dealer. Keep the aftermarket one in your glove box for an emergency spare.
Old 04-25-2014, 11:10 AM
Any other guesses?
Old 04-25-2014, 04:53 PM
Thanks for the insight Pikachu
Old 04-25-2014, 05:35 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Quote:
Originally Posted by TN Floorman View Post
Any other guesses?
Have you replaced the CPS yet? That suggestion wasn't in vein. Its textbook CPS failure.
Use only an OME sensor. Riffraff has them for sale
Old 04-25-2014, 05:39 PM
Pikachu's Avatar
Did a new sensor seem to solve the problem?
Old 04-25-2014, 05:53 PM
Havent been able to get one from the dealer yet.
Old 04-25-2014, 06:02 PM
Pikachu's Avatar
Oh. Well, in the meantime you could make sure the tin nut that holds the spacer and solenoid on the IPR is tight. If it's loose, it can affect the way the truck runs.
Old 04-25-2014, 06:24 PM
Ill look into that too. Where is the spacer on the IPR? I assume the tin nut is obvious if I look at the IPR. Thanks.
Old 04-25-2014, 06:29 PM
Pikachu's Avatar
The spacer is directly behind the solenoid, between the solenoid and the nut. It actually looks like it's part of the solenoid at first glance.
Old 04-25-2014, 07:46 PM
Thanks again. I've been having an oil leak, that I was trying to trace down too. Do you think it's possible the leak is coming from the IPR and that was causing my stalling problem? Or is it not likely to leak from the IPR?
Brain scratcher MI02SVT 1994.5 - 1997 7.3L Power Stroke Diesel 6 03-20-2016 11:50 AM
Surging once warm and at low RPMs HokieHiVPI 6.0L Power Stroke Diesel 3 03-03-2016 12:39 PM
2004 early 6.0 no start dothedew192 6.0L Power Stroke Diesel 10 02-21-2016 09:58 AM
FICM, FICM relay, or harness? madmatt1186 6.0L Power Stroke Diesel 4 02-02-2015 11:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
