Great Brake invention
I discovered a terrific seal for hydrolic lines. With old calibers it is sometimes difficult to get the copper or aluminum crush washers to seal completely.
I was trying and trying and was tightening so tight I was afraid I would snap the banjo bolt. Finally, after trying several types of copper and aluminum washers, I was at a fitting/hydrolic hose supply co., and the guy tossed a 'stater seal' (if I got the name correct.) on the counter. I was blown away. I had never seen one. I didn't know they existed. It is an aluminum crush washer with an O-ring bonded to it. I was told it is from aerospace industry.
I installed it and instantly it sealed, impervious to b.fluid or gas. I hope this post will help others in the future. k
Elliot Ness--
Thanks for posting that! That is exactly it! I swear by them now. 'Static seals,' I believe.
*Side note: I've noticed that since chain auto parts stores like A.Zone and O'Reilley's are doing away with fitting assortments and bolt and nut bins and the like, a need for small businesses who sell such items is growing.
They have several different names for 'em, but you DO need to be careful which ones you buy. You can see by the picture posted above that there are several different colors out there; If you get an actual aviation one, you'll need to make 100% sure it's compatible with whichever fluid you intend for it to have contact with.
Some are for engine oil; all of those that I've seen are black. They should be OK with just about anything in our trucks, but some of them are grey, red or whatever color. If you were to get one that is designed for a modern phosphate-ester hydraulic fluid, like Skydrol, it would swell to obscene proportions on contact with standard mineral oils and probably eventually decompose.
The metal the washer is made up of can also vary from super squishy aluminum to cadmium plated stainless.
Any of the generic ones you get from an auto place should be A-OK for anything inside a vehicle, though.
This chart is a handy little reference for them:
Genuine Aircraft Hardware Co
But that only works for ones meeting the NAS specification and likely wouldn't help for ones that Jegs sells
If you decide to use one of these things, make sure to log what part number you use and buy a few extra so you can have replacements down the line; you shouldn't re-use these.
Because I am the new guy I am going to get extra info. I am an A&P mechanic and can tell you that any of the "PRESSURE SEALING WASHERS" (REAL NAME) that are red or black should give you no issues on a modern vehicle. Blue however is primarily fuel and if I started posting diagrams of the colored dashes on the black O-rings you would get a headache. So to make life easier on everyone, here is where to get them from. They have brick and mortar stores as well, possibly in your area
McMaster-Carr
McMaster-Carr
Jeff Fisher
08-10-2013 08:09 AM
