Help: 295-65-18 Duratracs On 2" Leveled F-150 with 18x7.5" Stock Wheels? - Ford Truck Enthusiasts Forums
Old 04-24-2014, 04:42 PM
ToMang07's Avatar
ToMang07 ToMang07 is online now
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Question Help: 295-65-18 Duratracs On 2" Leveled F-150 with 18x7.5" Stock Wheels?
Just need to know from anybody that has or had this EXACT setup, is there any rubbing?
I have possession of my brother's truck while he's in Afghanistan, and I'm looking into putting bigger tires on for him. (His request.)
He wants as close to 34" that he can fit WITHOUT rubbing on stock wheels. I believe the 295-75R18 Duratracs are as close as we'll get.
He DOES want Duratracs. (His request.)
Truck is a 2004 STOCK F-150 w/5.4L, if does have a 2" leveling kit in it. (Block type)
Thanks for the help fellas!
Old 04-24-2014, 04:58 PM
motolorenzo's Avatar
motolorenzo motolorenzo is offline
motolorenzo is starting off with a positive reputation.
I have mine leveled (04 Lariat SCAB 4X4) with 305's on the same wheels. Works fine, no problems and looks much better than the 295's. Thats my 2 centavos. Renzo in Kau
Old 04-24-2014, 05:39 PM
ToMang07's Avatar
Quote:
With stock 18x7.5" wheels?
What kind of tires? One of the reason I'm looking for such a specific tire is Duratracs have very wide sidewalls.
Old 04-24-2014, 07:26 PM
ToMang07's Avatar
Bumpity...
Old 04-25-2014, 09:14 AM
twfish twfish is offline
twfish is gaining momentum as a positive member of FTE.
Usually what causes your rubbing is offset of the rim. A 305 is a 10 inch wide tire and I imagine putting that on the rim would cause it not to be covered under warranty. 295 will probably be fine. Thesed trucks can run 35 without rubbing
Old 04-26-2014, 01:22 AM
305's
What I'm running are BFG 305-65-18 AT, TA, KO, Load Range E, 3 Ply Side Wall, Aggresive Tread, rated at 65 psi.. When empty I run 45 psi., When heavily loaded with often 4000 lbs. in the bed I run 65 psi.. They are quiet for the tread design and ride good. I rotate at 5000 miles. I got on to these after the last set of ***** BFG OEM tires rated at 35 psi with 2 ply side walls. I had to order the set thru COSTCO because all the other dealers were over $200 more. Thru COSTO out the door the set was $1417.00 all included. I haul some heavy loads and some heavy boats quite often. You have more to choose from on the mainland and certainly better prices, but I'm happy with these. Thats the story. Renzo in Kau, Big Island, Hawaii
Old 04-26-2014, 07:31 AM
tjcprop's Avatar
tjcprop tjcprop is offline
tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.
I have used a 305/60 18 Pro Comp Xtreme MT which is more aggresive looking that the Dura Trac without an issue. More costly of a tire but a true 10ply.
Old 05-02-2014, 03:02 PM
ToMang07's Avatar
Fits like a charm, and looks great! Perfect! (Except for price.)
Before:
After:
Old 05-02-2014, 03:04 PM
ToMang07's Avatar
Old 05-02-2014, 07:45 PM
tjcprop's Avatar
That one picture of your finger in thread. Imagine the depth of thread being two fingers deep. That is Pro Comp Xtreme MTS
Old 05-02-2014, 08:18 PM
ToMang07's Avatar
Quote:
First....Bull chit. Seen 'em. No. From Pro Comps website, other than the 37" tires, the deepest tread they have is 20/32. Pro Comp Xtreme M/T 2 Radial - Pro Comp Xtreme M/T 2 Radial - Pro Comp Tires - Tires - by Pro Comp The 295-65R18 Duratracs are 18/32.
Second... Pro Comps wear out to quickly. They have too soft a compound.
Lastly....do you sell them or something? Your Pro Comps have nothing to do with this thread, nothing whatsoever.
So why a
re you posting twice about Pro Comps??? And not even the right size?
Old 05-02-2014, 08:56 PM
tjcprop's Avatar
No I don't sell Pro Comp. I drive on good tires than wear, handle and look great. Living in Canada with weather from +40C to -45C and 250cm plus of snow. I rely on my tires for snow plowing and towing in summer. There is a reason why the Xtreme MTS are worth more??
Old 05-03-2014, 03:42 PM
ToMang07's Avatar
Quote:
Originally Posted by twfish View Post
Normally is the time I step in and calm things down but seeing your a post master I dont think you need told. Hes gotten on my nerves too but we dont want to push users away
Normally.... I'd be right there with you.
But....as I clearly stated in the first post....this was a fitment question regarding one tire and one wheel. Not looking for other suggestions. And when you are posting multiple times in more than one thread, and posting NOTHING HELPFUL or even relevant to the thread(S)....you're gonna get called out.
Old 05-03-2014, 05:44 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Ease up on the language used when ya disagree with others, people.
I'm a nice guy and I prefer to give lots of leeway, but if I have to clean up the thread again due to language I'll be forced to take my Mr. Hyde potion.
Stewart
Old 05-03-2014, 05:54 PM
I agree, but he is still pretty new too the site. Im really not trying to stick up for him, I just dont want new users to see this and think that everyone is going to call them out
Tire fitment question jmw1856 Offroad & 4x4 1 12-04-2015 07:09 AM
Largest tire on leveled 04 F-150 (4x4) with stock 18" wheels? ToMang07 2004 - 2008 F150 3 11-12-2013 10:36 AM
will a 275 70 18 duratrac fit larestock 2009 - 2014 F150 1 10-26-2013 09:09 PM
Time for tires. Need your suggestions!! clintusaf 1999 - 2003 7.3L Power Stroke Diesel 32 02-02-2013 08:07 PM
1997 F-350 460 Towing Mods Update Dezertracer 1987 - 1996 F150 & Larger F-Series Trucks 5 03-08-2010 10:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
