Hazard and turn lights dont work
Ok, so I'm putting every thing back into the truck. I left the steering wheel resting on the floor and the wiring in. Every thing else came out because I had to cleaned out the smell of mice. After I installed the instrument panel I started the truck, there was no hazard and turn lights. I checked all the fuses under the dash and that round hazard fuse to. I checked all the fuses under the hood. I did have a bent brake plug blade to deal with. I need to replace a bad key cylinder, you can turn it without a key. It doesn't start it. I believe there was three plugs I unplug to lower the steering wheel. Park brake, brake pedal and plug under the steering wheel. Wipers work, all other exterior lights work. Interior roof light works. Rear brake lights? I believe there's a switch that includes the wiper arm, turn signals and hazard??? Thanks for any info. mike
Also no brake, reverse or instrument panel, lights
The column is installed. I can drive it around now.
Now that it's dark I can see there are no brake, reverse or instruments panel lights. Gauges with needles work. Cargo lights won't go off, even with with light switch pushed in.
Everything worked before.
mike L
Electrical Systems/Wiring
09-14-2014 06:56 PM
hihosilver0820
15
07-12-2013 11:42 PM
snook715
03-05-2011 10:38 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
01-04-2004 08:03 PM
