Steering issue. Truck tryin to kill me
Have an 06 5.4 f250 xlt sd. It is lifted an has 37s. But this prob jus started occurring. I'll be driving an either turn or go around a curve in the road am the steering will start to get stiff than it'll jerk the wheel out if my hand hard to the left, ill correct it than hard to the right. It goes back an forth for a bit than stops. Seriously almost killed me few times. Almost threw me in front of a semi. I noticed the u joint was broke so I replaced it an the ball joints. It still does it. Any suggestions? Any one have this problem before
Gonna kill me too!
Please email me with what the dealer finds! I've had this problem for a year. Nothing has fixed it. Whole front end rebuilt!
Nercothread! IIRC, the U joint/ knuckle on the right front, went out. The dealer replaced and it has been fine ever since. Since my truck has a towing control feature, this is what kicked in on me when it happened. Are you sure you don't have death wobble? I know some owner experience this. Myself knock on wood bave not had this issue with my ownership of any of my previous vehicles.
Yep likely the outer front drive shaft ujoints. Install Spicers and put the spicer grease in them at every oil change. Doesn't hurt to lock the hubs in and run with them that way for a day or two per month. Keeps them loose. Check everything out up front while your at it. If your doing the ujoints might as well do what ever else is in question.
