6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
90wt smell
Old 04-17-2014, 03:02 PM
sv250's Avatar
sv250
sv250 is offline
90wt smell
Im getting an occasional wiff of 90 wt inside the cab. Usually when stopping. I dont see any leaks on the diffs and ghe rims are oil free.
Any ideas?
Old 04-17-2014, 06:17 PM
Tom's Avatar
Tom
Tom is offline
Just to clarify, you say it smells like gear oil?
Old 04-17-2014, 07:15 PM
sv250's Avatar
sv250
sv250 is offline
Yes gear oil. I don't know what it could be.
Old 04-17-2014, 08:21 PM
Tom's Avatar
Tom
Tom is offline
Could be burning brakes, it's an acrid smell that isn't that dissimilar from gear oil. Have you checked for a sticking caliper?
Old 04-17-2014, 08:48 PM
sv250's Avatar
sv250
sv250 is offline
I just rotated the tires and checked the brakes. Pads and rotors look good. If it was sticking shouldn't I see some chattering othe rotor?
Old 04-17-2014, 09:08 PM
mohle's Avatar
mohle
mohle is offline
I've had a similar issue with my 06. It was the rear axles seals leaking. They leak ever so slightly and it seeps into the park brake assembly on the inside of the rear rotors. The heavier load you pull, the stronger the smell. There were no drops onto the ground, just a very small streak on the rear hub.
Old 04-18-2014, 07:12 PM
sv250's Avatar
sv250
sv250 is offline
Ill have to pull the rotors and check that out. I only get this smell once in a while then only for a few seconds.
I have been running in 4 hi in the rain since my "limited slip" sucks ***. I dont go over 65 in 4wd. I hope that hasnt caused a leak.
Im also runni g an h and s tuner. Ive only made 3 passes in the truck so i wouldnt think the pinoon seals would be slowly leaking. That and i dont see any fliid.
This started about 1k miles ago after my last oil change and rotate.
Old 04-18-2014, 08:34 PM
Tom's Avatar
Tom
Tom is offline
That would not cause a leak. Some folks up north spend half the year in 4WD and they don't leak. Not sure why you'd need 4WD in the rain though.
Old 04-18-2014, 09:44 PM
sv250's Avatar
sv250
sv250 is offline
One bald tire spins if i just tap the gas. I go no where. Bigger meats coming soon
Old 04-19-2014, 04:28 AM
slowmans's Avatar
slowmans
slowmans is offline
Do you have the CCV reroute ?
Old 04-19-2014, 04:52 AM
sv250's Avatar
sv250
sv250 is offline
Yes i do. Its def a gear oil smell though.
Old 04-19-2014, 12:46 PM
slowmans's Avatar
slowmans
slowmans is offline
Thats what it is, mine smells the same way.
Old 04-19-2014, 04:40 PM
sv250's Avatar
sv250
sv250 is offline
Ok well thats a relief. I guess ill need to route it further out or add some sort of filter.
Old 04-21-2014, 07:05 PM
wp6529's Avatar
wp6529
wp6529 is offline
Check the left frame rail roughly under the driver's seat, the front axle breather is located up there (follow the hose to the diff), and if you've been running in 4WD on moderate traction roads you may well have overheated the front diff and caused some oil to puke out of the breather.
These trucks are 4WD, not AWD and do not have a center differential so unless the road is *really* slippery things will bind up and overheat. I cooked my front diff driving an extended distance in 4HI in *6" of slush* on the highway, and slush is far lower traction than rain.
Old 04-23-2014, 06:15 PM
wp6529's Avatar
wp6529
wp6529 is offline
Originally Posted by Canelo Elizondo
I agree here. You should not experience a leak.
Regards
Rod
DPF Delete
It is not a leak, it is overheating the front axle which cause some of the gear lube to puke out of the axle vent tube which is routed up into the left frame rail as I noted. I'd put 95% odds that this is what is happening to the OP, and it will ultimately result in a rebuild of the front axle if he continues using 4WD on high traction surfaces at speed.
Quick Reply: 90wt smell
