1961F100 Turn Signal Help
Hopefully you guys can help because I am stuck.....
What would prevent my turn signal lever from staying engaged? In order for the turn signals to stay on, I have to hold the lever down. But when I let go of the lever, the turn signal turns off/stops.
I recently replaced the lever, switch, and plate.
*just realized I made a typo on post subject. Truck is a 1962, not 1961. Sorry.
Thanks,
Thanks,
Did you replace the switch with a junkyard switch or a new switch? I had the same problem but only cause I replaced mine with a junkyard switch. I bought one from Bobs F100 for 40 bucks and that solved the problem. The plastic on the switch eventually wears out and won't hold the lever in place. Let me know how it turns out.
I bought a 1965 switch from Bobs F100 for 40 bucks and that solved the problem. The plastic cancelling cam of the 1965 switch breaks, and won't hold the lever in place.
1961/62 F100/250 2WD: The T/S switch (C0DZ-13341-A) does not contain the mounting plate (C0DF-13304-A). It's a separate part and was sold by itself.
The T/S handle threads into the steel mounting plate, not into the switch. Turn signals canceled by mounting plate which contains two tiny coil springs.
1960/62 Falcon/Comet & 1961/62 F100/250 2WD:
C0DZ-13341-A .. T/S Switch / Obsolete ~ 251 available NOS
C0DF-13304-A .. T/S Switch Mounting Plate / Obsolete ~ 25 available NOS
If the signals cancel, but do not work, the fault lies with the flasher, defective switch, burned out bulbs, corroded bulb sockets, faulty wiring.
This may help
Picture 1 shows the switch plate upside down. See the "bump" on the far right hand side? It engages two "ramps" on the side of the switch - see picture 2. Sorry its not very clear but you can see them. See picture 3 for final assembly. The bump on the switch plate engages the ramps and holds the lever/plate in position - note that a tiny spring and clip holds down the switch plate so it will engage the switch post and the ramps. Most likely this is what is worn out. I bent the bump on my switch plate down to improve the engagement and it worked perfectly. Did this help or hinder?
