Edelbrock carb install question - Ford Truck Enthusiasts Forums
Old 04-23-2014, 07:58 PM
5280's Avatar
5280 5280 is offline
5280 is gaining momentum as a positive member of FTE.
I ordered an Edelbrock 1411 carb and a Performer manifold for my truck, 85' F350 460, the truck in my signature. How do you guys like to adapt the factory fuel line to an aftermarket carb?
The factory fuel line is metal, currently comes in to the front driver side of the carb. The Edelbrock fuel fitting is on the passenger side, towards the rear of the carb.
I know I can cut the factory hard line and splice in a rubber line. Wondering if anybody has any better ideas, maybe keeping with all hard line? Edelbrock offers a coupe of options Performance Carburetors and Accessories - Fuel Inlet and Filter Accessories - Edelbrock, LLC. there will still be some rubber line involved though.
Old 04-23-2014, 08:05 PM
RL250's Avatar
RL250 RL250 is offline
O/O Desert Rat Customs
RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.RL250 has a very good reputation on FTE.
You could always get some metal tube and fab a whole new line. I'm leaning toward the spliced line.
Old 04-23-2014, 08:26 PM
5280's Avatar
Quote:
A spliced line would be the easy way out. I'm not sure if I want to invest in a bender and a flaring tool to make a hard line, but that is a good idea as I'm not sure if I like the idea of a rubber line on top of the engine.
Another question; here is a shot of what I assume is the fuel filter? Why two inlet lines?
Old 04-23-2014, 08:30 PM
bruno2's Avatar
bruno2 bruno2 is online now
bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.bruno2 has a great reputation on FTE.
Is one a return?
Old 04-23-2014, 08:46 PM
5280's Avatar
Quote:
Originally Posted by bruno2 View Post
Is one a return?
That would make sense. I did not realize carbed engines had return lines?
Old 04-23-2014, 09:24 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
IIRC some 460s have return lines, the Hot Fuel Handling package is designed to prevent vapor locks.
BTW I have no idea what engine you're talking about as I don't display sigs or avatars by default.
Old 04-23-2014, 09:32 PM
5280's Avatar
The truck does have electric pumps in the tanks, I can hear them. I will trace the line back when I install the carb this weekend.
Old 04-23-2014, 09:56 PM
RL250's Avatar
It looks like it might be a feedback system I keep hearing about. That would explain both the pumps and the return line.
Old 04-23-2014, 10:02 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
That is the hot fuel system that has a return line. You can come off the carb side of that with a rubber hose and run that to the carb inlet. However, I had to buy an angled inlet adapter to get my factory air cleaner to sit down correctly.
Also, you need to check fuel pressure. Edelbrocks are great carbs, but they don't like more than about 6 psi of fuel pressure and you may have more with the electric pumps. If so install a fuel pressure regulator to drop it down to 5.5 psi.
Old 04-23-2014, 10:13 PM
5280's Avatar
Is the "hot fuel system" something I want to keep in service or should I plan on reworking it with no return?
Old 04-23-2014, 10:15 PM
ctubutis's Avatar
The feedback system (on the I-6 and 302 only in this era) has a solenoid the carb with wires that eventually connect to the computer.
Old 04-23-2014, 10:16 PM
ctubutis's Avatar
My opinion is that Ford implemented that system because of vapor lock troubles, so why get rid of a cure to a known problem?
Old 04-23-2014, 10:25 PM
5280's Avatar
Quote:
Just asking. If it works I have no issue keeping it. So far, I have not had what I feel are fuel delivery problems. The truck ran okay on it's maiden voyage to my house at 9000' from Denver. Somewhat gutless but I think that can be attributed to an internally leaking carb and lots of vacuum leaks. Or at least I hope so I'm looking forward to installing my new carb.
Old 04-23-2014, 10:27 PM
5280's Avatar
It is a 460
Old 04-23-2014, 10:31 PM
Gary Lewis's Avatar
I would keep the hot fuel system. It isn't broken, so don't fix it.
Wanting Carb to Fuel Pump Line Routing Pics FordIowan 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-29-2016 08:41 AM
Fuel Line Pump to Carb hulleywoodworking 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 02-04-2016 01:18 PM
Carter AFB Carburetor ( Edelbrock ) Paso1 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 03-09-2015 01:22 PM
Carb Confusion.... wideopen 1967 - 1972 F-100 & Larger F-Series Trucks 5 04-10-2014 11:12 PM
Edelbrock performer carb fuel line 77FordTruckMan 1973 - 1979 F-100 & Larger F-Series Trucks 13 11-06-2008 01:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
