Top reasons why your under hood light don't work, or is low light.
Old 04-23-2014, 08:09 AM
reamer's Avatar
reamer
reamer is offline
Took a spare one apart to see how it works.
You must drill out the rivets, fairly simple, just keep a little pressure on the cover so it don't pop off.
Here's the inside, the two brass circles were contaminated with junk, I cleaned them with dry scotchbrite.
Clean the mating contacts too. (on top cover)
Here's where the major problem is, the mercury bulb may not be making good contact because of corrosion. In this photo the actual brass contact that touches the right-side, center "nipple" of the mercury capsule is missing!
Clean all the corrosion in the capsule's cradle
Once cleaned up, and no wires are frayed, (and bulb works) it will be "high powered" again.
If found that where the bulb wire goes into the case, the hole is too small and restricts the wire from moving in and out of the cassette easily. (you pull it out and it wont go back in). Its not a weak spring, it's wire restriction. I used an X-acto knife and enlarged the hole. Works beautifully now.
Old 04-23-2014, 08:22 AM
oneowner83's Avatar
oneowner83
oneowner83 is offline
I cleaned mine up many years ago and got it working. After it failed again years later I decided the damn thing wasn't worth fooling with.
Old 04-23-2014, 03:37 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Rep's to you, Ron! I have a working one and a couple that don't. May just take one apart some day and fix it, now that you showed me how.
Old 04-23-2014, 03:55 PM
reamer's Avatar
reamer
reamer is offline
Very Simple design. when drilling out the rivets flip it so you see the bottom of the rivets, easy to drill this way, then flip it over and carefully take the top off. Ya do it right and the center spring will not unwind on you.
reamer's Avatar
reamer
reamer is offline
would you happen to know the correct mounting position on the hood?
Old 04-23-2014, 04:01 PM
ctubutis's Avatar
ctubutis
ctubutis is online now
Old 04-23-2014, 04:04 PM
reamer's Avatar
reamer
reamer is offline
Thanks Ctubutis!
Care to explain the small airhorn on the air cleaner, or is that country "Ram Air" mod?
Old 04-23-2014, 04:06 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Yes, and thanks for asking.
Old 04-23-2014, 04:18 PM
reamer's Avatar
reamer
reamer is offline
You sound like my wife.............
Old 04-23-2014, 04:19 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I feel special since I KNOW what you think of her. So, to be compared to her.....
Old 04-23-2014, 06:25 PM
maytag906's Avatar
maytag906
maytag906 is offline
Great thread! I'll have to investigate mine soon.
Old 04-23-2014, 07:32 PM
ctubutis's Avatar
ctubutis
Bulb type 89 or 105.
The air horns, that's not my truck, no idea there...
Old 04-23-2014, 07:52 PM
OldBlue83's Avatar
OldBlue83
OldBlue83 is offline
I acquired one of the underhood lights years ago and I think it is a fantastic and useful feature. I use it all the time. However, I thought it made more sense to mount it on the drivers side of the hood where it can light up the engine oil dipstck, master cyl, rad reservoir, pwr. steering, and windshield washer reservoir. The only thing it was doing over on the other side was to light up the spare tire jack area.
Old 04-23-2014, 07:58 PM
oneowner83's Avatar
oneowner83
The light pulls out and retracts!!
Old 04-23-2014, 08:09 PM
reamer's Avatar
reamer
reamer is offline
you can light up the rear bumper, or change a rear tire with it extended out.
Quick Reply: Top reasons why your under hood light don't work, or is low light.
