help me crunch my numbers - Ford Truck Enthusiasts Forums
Old 04-23-2014, 02:40 PM
superstroked6.0's Avatar
superstroked6.0 superstroked6.0 is offline
superstroked6.0 is gaining momentum as a positive member of FTE.superstroked6.0 is gaining momentum as a positive member of FTE.
Ok, I have posted in a couple threads about a low power problem and have been following them to see the problems they are having. Yesterday I bought a scan gauge 2 and put in a bunch of gauges. The truck also seems to roll over quite a bit before starting and today leaving work I didn't think it was going to fire, so we can add hard start to the problems. I have some numbers from my gauge, they are.
KOEO
FMP 48
FVP 12.5
FLP 12.5
IPR 14.4
ICP 0
BST 0
VGT 0
LOW IDLE
FMP 47.5-48 bounces back and forth
FVP 13.5
FLP 13
IPR 21.4
ICP 640 went as high as 1560 cranking before start
BST 0
VGT 69
Drove home to get fluid temps up to get high idle numbers.
EOT 173*
FMP 46
FVP 13.5
FLP 13.5
IPR 38.7
ICP 1520
BST .4
VGT 36
High idle was done at 2500 rpm, engine ran ruff and wanted to climb and fall, it was hard to hold at 2500.
I don't have WOT numbers or number with cruise set at 60, if I need them I can get them.
Do you guys think it is the ficm?
Thanks for any help!!
Old 04-23-2014, 03:58 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Must be an 03/04 to have idle ICP around 640.
I would check fuel pressure.
Josh
Old 04-23-2014, 04:22 PM
03, 115000 mi. No tune. Is there a xgauge for fuel pressure I didn't see it anywhere.
Old 04-23-2014, 04:46 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
You need to install a sender and sep. gauge. OBD ll doesn't report fuel press.
Old 04-23-2014, 04:51 PM
Quote:
Ok, guess I'll have to find a gauge then.
Old 04-23-2014, 05:24 PM
Bullitt390's Avatar
You're numbers so far look fine, EOT @ 173 indicates the engine was still warming up, I would guess your ECT was near 180 at that point.
What was the IPR% during the long crank?
Josh
Old 04-23-2014, 08:19 PM
I don't remember what ipr was, thought I wrote it down. Ill pay attention in the morning when I go to work after it has sat overnight. The other thing I forgot about is if I take off hard from a dead stop it will fall flat on it's face and blow blue/white smoke. It wont shift until I let off the pedal. I'll try to get a video of it doing it.
Old 04-23-2014, 10:00 PM
CPB1's Avatar
CPB1 CPB1 is offline
CPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to behold
Does it show any codes?
Old 04-24-2014, 12:52 AM
Super Duty Service Super Duty Service is offline
Former Vendor
Super Duty Service has a great reputation on FTE.Super Duty Service has a great reputation on FTE.Super Duty Service has a great reputation on FTE.Super Duty Service has a great reputation on FTE.
Can you post icp volts at koeo??
Old 04-24-2014, 04:55 AM
No codes, ICV is 1.3 koeo. This morning IPR hit 57.7 while cranking. It started fine. On the way to work FMP bottomed out at 44.5 once. It is up and down the whole time, usually from 46-48. Never more then 48
Old 04-24-2014, 07:31 AM
Bullitt390's Avatar
ICP should be .18-.25 volts KOEO
Josh
Old 04-24-2014, 01:40 PM
Just got out of work, ICV KOEO is .09
At low idle ICV is 1.15
FMP is 47.5-48
IPR jumped to 76 till start then dropped to 27 at idle
Old 04-24-2014, 01:52 PM
Bullitt390's Avatar
ICP sensor and/or pigtail is fubar'd
Josh
Old 04-24-2014, 05:55 PM
What about the ficm power fluctuating from 45.5 to 48? I've read on here that 45 means it's toast.
Guess I'll call the dealer and get an ICP and harness.
I was hoping I wouldn't have to start wrenching on it right after buying it.
Old 04-24-2014, 06:49 PM
mustang_309's Avatar
mustang_309 mustang_309 is online now
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
Get your ICP problem fixed and check your electrical system, load test the batteries separately ( completely disconnected from one another ) and if you find one bad battery replace them both. The FICM voltage fluctuation could be due to failing batteries and or alternator. The bad thing about these trucks is new owners of used trucks get the brunt of the neglect that the previous owner enjoyed. And neglect usually ends with pretty hefty repair bills, but the good thing is, that once you get everything in order and maintain it properly you will have a very dependable truck.
Possible bad alternator? Also, low Scangauge II readings: UPDATE on pg. 2 Godzillamax 6.0L Power Stroke Diesel 22 06-04-2015 10:41 PM
Truck runs rough, numbers show anything? 56fordfella 6.0L Power Stroke Diesel 101 12-13-2014 12:49 AM
30.5 Volts for FICM (bad) but no reading for FLP andysam 6.0L Power Stroke Diesel 40 03-26-2014 06:18 PM
early 03 6.0 problems 190,000 miles USMCveteran 6.0L Power Stroke Diesel 123 01-27-2014 10:48 PM
Under Load 2000 rpms shaking/missing 99ExpyProblems 6.0L Power Stroke Diesel 13 08-22-2013 10:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
