Suggest next mod's for my 6.4 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 04-23-2014, 01:36 PM
1FastGambler 1FastGambler is offline
1FastGambler is starting off with a positive reputation.
'08 F250 crew cab SWB 4x4
Current mileage: 53k
current mod's: Spartanized, 4" from down pipe back, no muffler, Cold air intake, & Aftermarket deep trans pan.
Looking for suggestions from only those with personal first hand experience with specific products on YOUR 6.4.
My priorities are: Durability/Longevity, fuel economy, then power(has plenty of power as is) I do not intend to increase power any more unless it is simply a byproduct of improvements in another area.
Would like to hear your personal reviews on the following products, plus feel free to discuss any other relative products you have installed on your truck...
  • Coolant Filtration system (Sinister)
  • Cold side intercooler pipe and boots (Mishimoto)
  • EGR Delete
  • Blow Off Valve
  • Inercooler
Old 04-28-2014, 12:23 PM
speedyfz1's Avatar
speedyfz1 speedyfz1 is offline
speedyfz1 is starting off with a positive reputation.
MOD's
You should do the down pipe to help lower egt's.
Old 04-29-2014, 08:41 AM
Lowering EGT's would be good. Whenever I'm towing my camper up dirt roads in the mountains where speed is limited to less than 40 MPH I've had to stop and let my tranny cool down several times.
Do you think that swapping out the down pipe would make enough of a difference that I would see lower tranny temps?
Old 04-29-2014, 10:52 AM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
I find it hard to believe your overheating the trans, I don't have a Spartan tuner but somebody might jump in on how you can set the transmission up with that tuner.
Old 04-29-2014, 11:31 AM
speedyfz1's Avatar
Mod's
It will not lower the tranny temps as a whole. It will lower exhaust temps with less back pressure. Your tranny temp issue is a separate problem that needs to be looked at.
Old 04-29-2014, 07:32 PM
I don't think the heat is caused by anything other than towing about 14k LBS up a long steep mountain road at speeds below TC lockup.
I tow frequently and this is the ONLY time I ever see the Trans get hot. Mountain passes on the highway at 50-80 MPH are never an issue.
Tuner question 08 6.4 Matt10 1999 to 2016 Super Duty 3 06-12-2016 09:36 PM
Ordering Banks Power Pack - Questions IcutMetl 1987 - 1996 F150 & Larger F-Series Trucks 11 05-25-2016 04:25 PM
Spartan Kit with straight pipe and AFE cold air intake for 6.4L ETKMS Ford Truck Parts for Sale 2 09-18-2015 12:58 AM
Don't do the doo Tugly 1999 - 2003 7.3L Power Stroke Diesel 60 03-04-2015 07:09 AM
6.4 what mod next? caddy 6.4L Power Stroke Diesel 13 06-24-2013 05:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
