Top reasons why your under hood light don't work, or is low light.
Took a spare one apart to see how it works.
You must drill out the rivets, fairly simple, just keep a little pressure on the cover so it don't pop off.
Here's the inside, the two brass circles were contaminated with junk, I cleaned them with dry scotchbrite.
Clean the mating contacts too. (on top cover)
Here's where the major problem is, the mercury bulb may not be making good contact because of corrosion. In this photo the actual brass contact that touches the right-side, center "nipple" of the mercury capsule is missing!
Clean all the corrosion in the capsule's cradle
Once cleaned up, and no wires are frayed, (and bulb works) it will be "high powered" again.
If found that where the bulb wire goes into the case, the hole is too small and restricts the wire from moving in and out of the cassette easily. (you pull it out and it wont go back in). Its not a weak spring, it's wire restriction. I used an X-acto knife and enlarged the hole. Works beautifully now.
I acquired one of the underhood lights years ago and I think it is a fantastic and useful feature. I use it all the time. However, I thought it made more sense to mount it on the drivers side of the hood where it can light up the engine oil dipstck, master cyl, rad reservoir, pwr. steering, and windshield washer reservoir. The only thing it was doing over on the other side was to light up the spare tire jack area.
