Truck Pulls to Right, Pulls to left on Braking
My 2003 F250 6.0 pulls to the right when driving at any speed. In order to keep it going straight the steering wheel must be slightly tilted to the left, not much but a little. When the brakes are applied hard it will go to the left slightly if you are not holding the wheel good. Neither of these are terrible, just a nuisance. I'm worried about uneven tire wear too. One fromnt wheel bearing was replaced a few weeks ago. It had this problem before that and still does after. Does this sound like an alignment or maybe something more?
Thanks
Thanks
If it's four wheel drive it's pretty sensitive to tire pull. An otherwise perfectly fine tire can make it pull just slightly one way or the other. They are also pretty sensitive to the road crown. Mine is straight as a arrow in the slow lane, but if I change to the passing lane the crown is the other way and it pulls to the left.
Brian
Brian
I took the truck in the shop and looked at it. A buddy told me that the brake might be stuck too. Lifted front axle up and both wheels turn freely. No brakes stuck. He then said the tires could be shaped unevenly and cause the slight pull. So he told me to cross rotate the front tires and see if that fixes it. So far it no longer pulls when driving but still has a slight brake pull. Definitely an improvement and good news it's not a brake.
Brian
Brian
Dick
It pulls to the left during braking, more of a slight jerk left then straightens out some it seems like. Brake hoses looked good from what I saw and still no pulling while driving after switching tires on the front, only when braking now. My alternator went bad so I'm currently working on that too. Thanks for the help
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
10-01-2014 11:28 AM
