Fuel tank delete
Fuel tank delete
as soon as I can get into my new garage I'll be tearing my f350 completely down, one of my plans is to build a dumping flatbed with the looks of the cm brand, my front fuel tank is inoperable and rotted, I would like to completely remove it from the truck and just have my rear tank, I would like to house the hydraulics where the front tank is.
How can I go about capping the high pressure fuel lines? I haven't looked much into it but I was thinking about buying a junkyard sending unit and cutting the fuel fitting pieces off then tig welding them shut and hooking them into the fuel lines on the frame, has anyone done something similar before?
on
5 minutes with a grinder and you can make plugs for the lines. The piece on the top right is one of the plugs I made from the stud below it.. cut off the threads and shape the nut so that it can be retained by the factory clips. Note you will need 2 different sized studs to make plugs for both lines. The part on the left is a check valve from the factory recall and is not related to this.
Marine5811
06-20-2010 04:16 PM
newtattoobob1
10-21-2009 08:01 PM
